AEM UEGO misbehaving
Old Dec 9, 2010 | 06:12 PM
AusS2000's Avatar
Default AEM UEGO misbehaving
I hadn't watched my AFRs in a while as I have been monitoring ECT like a totally paranoid hawk.
I ran some logs over the last few weeks and noticed my AFR shows rich under boost (as low as 11:1) but never climbs above 14.2.
I recalibrated yesterday and fixed a broken wire (not sure if that only happened when I inspected it but it's fixed now anyway) but it is still not giving a good reading.
It is an AEM 30-2301 single channel controller and sensor, plugged into an AEM EMS 30-1012 and AEM Serial Gauge.
Does anyone know if not being able to register a lean reading is a sign the sensor is gone, the controllers gone, or the whole thing needs replacing?
Old Dec 9, 2010 | 06:35 PM
neeman77's Avatar
This might help:
[media]http://www.youtube.com/watch?v=1mb4VmDd0ao [/media]
Old Dec 9, 2010 | 07:07 PM
AusS2000's Avatar
Cheers, but I seem to have the opposite problem.
I'll disconnect and do his tests and see how it pans out. Cheers.
Old Dec 9, 2010 | 07:10 PM
neeman77's Avatar
Also notice when you unplug the sensor the gauge should go to 14.7-14.8 a/f. And no problem, hope it helps!
Old Dec 9, 2010 | 07:14 PM
AusS2000's Avatar
Yeah, I'll look out for that too.
Old Dec 10, 2010 | 01:37 PM
s2konroids's Avatar
I had a similar thing to me, after going through a lot of trial&error and fault finding it ended up that the sensor had more or less failed (it got progressively worse).
Old Dec 13, 2010 | 07:30 PM
AusS2000's Avatar
Today I disconnected my sensor and the reading in the AEM Pro software stuck on 14.2. I adjusted the gain until it was pretty much on 14.7 (gain of 1.00).
Then reconnected it and ran the car. It showed 19 or so off and a fairly lean reading up in the 15-16 range but varied quite a bit when running.
I'm pretty sure the car isn't running lean. Is this the sort of behaviour one would expect of a dud sensor?
Old Jan 3, 2011 | 06:04 PM
AusS2000's Avatar
Problem solved.
Solution was to order a new sensor, go away on a 16 day cruise around New Zealand, then install new sensor on return.
The cruise is not entirely essential but highly recommended.
BTW, I plugged in the new sensor and did the tests with the brake cleaner. Reacted as expected.
Old Jan 3, 2011 | 07:31 PM
m R g S r's Avatar
lol have fun and good luck fixing it!
Old Jan 3, 2011 | 08:14 PM
neeman77's Avatar
hooray I love when things get fixed!
