AEM Wideband Install
Ok, so, everything seems fairly simple, im having my friends dad just weld the new bung onto my test pipe a little bit after the first o2 sensor, but here is the part that im confused about. I know the black wire is a ground (thats easy), but the red wire is supposed to go to my ignition..The only problem is that my water pump goes into that spot i believe....So when i turn the key, thats the only time the pump will start going which is what i want the Wideband to do...Do i just have to tap into the water pump wire???? Has anyone had to do this install with a comtech supercharger? Any help would be really appreciated, thanks guys.
I wouldn't mess with the water pump. Use the spare spade connector in the fuse box under the dash
I have my wideband wired there, and it works
and now you can connect it to the "accessory" tap on the fuse box. Note where it is in the picture, on the left hand side of the fuse box- it's the third "hole" down from the top. This is the one switched with the ignition (alternatively one is for the lights, and the other for constant power). Be sure to slide the connector over the spade (male) contact in the hole.
Just use an add a fuse and place it in the Accessory space.
i just did the wideband install thanks to this picture. yes the picture is accurate its the third bottom plug. and there a bunch of wires grounded next to it on the wall. plug the power wire in there and ground the other.....BAM you got ignition power
Thanks spectacle!!!
Thanks spectacle!!!
