AEM Wideband not reading
Old Dec 29, 2009 | 07:21 PM
itlynstalyn's Avatar
Originally Posted by Spoolin,Dec 29 2009, 07:19 PM
Is the gauge grounded? I believe it needs to be on a good ground. Also, did you run it through the calibration?
It's grounded through the emanage ultimate harness. I didn't think there was a calibration sequence for the AEM and it was strictly for the innovative. I obviously could be completely wrong.
Old Dec 29, 2009 | 07:37 PM
Spoolin's Avatar
I'm not too sure on the calibration with the AEM. I was just throwing that out there to see if it may help. I have the Innovate XD-1 so I have to calibrate it.
Old Dec 29, 2009 | 07:45 PM
TRBOKEV's Avatar
Aem comes pre calibrated.
Old Dec 29, 2009 | 07:49 PM
Originally Posted by TRBOKEV,Dec 29 2009, 08:20 PM
Are you running both the power and ground to the greddy power output? You should be if that's where you are getting your power..
Mine was hooked up this way when I had it and worked fine.
Yeah it's just giving me the three blank lines. I'm a little annoyed at the moment, I wonder if the sensor is already going bad? I'm going to recheck all the connections tomorrow to make sure everything is working.
Old Dec 29, 2009 | 07:54 PM
Spoolin's Avatar
Did you happen to accidentaly drop the o2 sensor or bang it up against something? I know they are sensitive to being banged around.
Old Dec 29, 2009 | 08:01 PM
TRBOKEV's Avatar
Double check the plug connections.
You got power so it's either the harness, the sensor or one of the plugs.
Good luck Devin.
Old Dec 29, 2009 | 09:09 PM
Good luck Devin.
Thanks Kev. Hopefully the sensor connector is loose somewhere. I'd hate forthe sensor to already have gone bad for some unknown reason.
Old Dec 29, 2009 | 09:13 PM
jari8378's Avatar
call me 909-580-4155 and ill walk u through it
tomorrow around 1pm
Old Dec 30, 2009 | 05:37 PM
tomorrow around 1pm
Thanks I'll most likely call you when I get back to LA in the next couple of days.
Old Dec 30, 2009 | 06:18 PM
eflove's Avatar
Not sure but this might help. [media]http://www.youtube.com/watch?v=1mb4VmDd0ao [/media]
