AEMs adj. fuelessure regulator!!
Old Jul 10, 2017 | 08:37 AM
Smokey Donuts's Avatar
Are you running a fuel pressure sensor? I have the AEM FPR and a SOS fuel pressure sensor kit with AEM Fuel pressure sensor and i am having semi erratic readings as well. Not sure if its the FPR or the fact that I didnt receive the buffer that goes in between the stainless line and the pressure sensor.
Old Jul 10, 2017 | 09:03 AM
MorngWoodStewie's Avatar
I have all that. Did not install the "buffer" either. Can u goninto some detail of the behavior so i can compare. Btw the buffer wouldnt allow me to tighten the fitting enough to NOT leak so i applied more pressure to tighten and it about stripped the npt fitting. Probably some frustration relieved by not receiving it lol.
Old Jul 10, 2017 | 11:10 AM
The readings were never a nice steady rate, even at idle. they would bounce around from 34-38psi and we could never truly "set" base pressure. Also during a WOT pull it would fluctuate +/- 10psi. I have a feeling it is the lack of buffer because that npt fitting is cupped to seat nicely with that piece. Glad I'm not the only one in this boat lol. I need to increase fuel pressure as i hit 100% inj duty cycle at 8200+ rpm.
camuman
Jun 20, 2012 07:41 AM
s2kbuild
Apr 22, 2012 03:59 AM
spectacle
May 10, 2010 03:00 PM
dibi
Sep 30, 2009 06:57 AM
slammed ap1
18
Mar 19, 2009 10:06 AM
