AFI Twinscroll manifold
Old Nov 29, 2012 | 10:09 AM
zaff's Avatar
Default AFI Twinscroll manifold
So I recently purchased an AFI Twinscroll T4 manifold divided and I'm curious if anyone would like to share their experiences with either a T3 Twinscroll manifold divided or a T4 Twinscroll manifold divided.
If I had a Precision 6262 with .84 AR turbo, how much lag wil there be on an unopened F20c motor? Is a T4 too big?
I've had the opportunity to chat and communicate with Brad about making a T3 divided manifold but, I've been discouraged by him multiple times to stick with the T4 divided manifold.
I would appreciate any insight. As always, I don't mind spending money, just not wasting money.
Old Nov 29, 2012 | 10:25 AM
Honda_Mad's Avatar
I have a the T4 divided with a Precision CEA 6265 T4.81, spool is decent and pulls hard to redline. You won't be disappointed.
Old Nov 29, 2012 | 10:56 AM
zaff's Avatar
YOu meant a 6266? At what rpm does you spool start? Is your F20c unopened?
Old Nov 29, 2012 | 11:07 AM
Irishflame27's Avatar
The 6266 is the replacement for the 6265 which used to be available when the 62XX series turbos were released...
Here is the deal, The divided T3 is a waste of time in my opinion for the S2000 and basically all honda engines that feature the volumetric efficentcy that we are so lucky to have. The F20/22 moves goobs of air and require relatively large turbine housings so back pressure will not become and issue.When running in a divided (not twin scroll)setup, you want to run a larger than normal turbine housing, because the internal divider is actually making your .84a/r housing smaller in terms of volume, than that of a open .84a/r unit.
Stick with the T4 and dont look back, you will have tons of sizing options available to you in a T4 footprint, while the T3 are very few and far between...
Old Nov 29, 2012 | 01:14 PM
jordannn93's Avatar
I have t4 afi twinscroll manifold. I have a borg warner s362 1.10ar. I notice I start building boost around 3500 and it really gets going around 5000rpm
Old Dec 1, 2012 | 12:53 AM
zaff's Avatar
Originally Posted by Irishflame27
Originally Posted by zaff' timestamp='1354218961' post='22179993
[quote name='Honda_Mad' timestamp='1354217111' post='22179901']
[/quote]
Thanks for your precise and informative description. When the whole set-up is complete, I will make sure to update.
Old Dec 1, 2012 | 02:53 AM
riceball777's Avatar
a t4 twin scroll manifold and turbo is the ultimate setup. I have a t3 open scroll setup on my s2000 which can be speen in my signature but I do have a t4 divided fullrace manifold with a t4 divided 1.06ar gt3582r on my stock 2003 evo 8 block. I can tell you from persional experance that my t4 1.06 divided gt3582r setup spool faster and makes more power than my old open scroll/undevided t3 .63ar gt3076r setup.
Old Dec 1, 2012 | 09:51 AM
zaff's Avatar
I noticed that all who have responded, have at least 1.0 AR or bigger. Was my selection of the 6262 with a .84 AR a poor choice? Should have I done a Precision 6266 instead?
riceball777
Nov 24, 2015 08:29 AM
