AFR difference spring pressure and boost solenoid
Well we probably found the problem. One of the wastegates was damaged, really no idea how. The membrane was damaged and the cilinder didn't function correctly.
Getting a new one tomorrow (Tial mvs 38) so we can see what happens. We also installed a back pressure sensorplate.
I ended up shaving off some material from the bolt so it wouldn't protrude out the hole. Just FYI hopefully the new one won't have any issues! Good luck!
Hey we did a good dynorun today. Finally no problems at all. Still on normal cams, tomorrow on Brian Crower stage 2 turbo cams and more boost.
Boost: 0.9 bar
Timing: 20 degrees (above 6500rpm, under that 19)
Torque: about 420Nm at 4700rpm
Power: 455bhp at 8700 rpm
Fuel: euro95 (91 in the states?)
this was an earlier run where you can see the temps and some other values
Boost: 0.9 bar
That's the idea yes. Being done today. If the cams are an improvement @0.9 bar then they will probably be so @1.8bar.
Originally Posted by sohc_mshue' timestamp='1322657936' post='21197133
So did you figure out why the afr was off from simply activating the solenoid?
Yes it is, cost a shitload of time and money before we began doubting that. The springs are very small at that size so we sent them off the have measured exactly. That's when we found out.
By the way, does anybody have an adjustable cam gear for sale? We're trying to install the Brian Crower cams but it's pretty hard without the adjustable gears.
Or does anybody have good tips how to do it with the stock gears?
