After market fuel injector spacers
Old May 19, 2006 | 11:53 AM
gotswap's Avatar
Default After market fuel injector spacers
I read on here somewhere and can't seem to find it. You can get spacers at Home Depot. What do they look like? Part number would be helpful if at all possible.
Thanks,
Mike
Old May 19, 2006 | 12:14 PM
Sideways's Avatar
The spacers from RC are aluminum tubing cut to 0.200 inches. You can just use washers that approximate that spacing. The washers go under the 3 posts rather than on top. They will not work on top, no threads left for the nut.
Old May 19, 2006 | 05:22 PM
gotswap's Avatar
Excellent!!! Thanks.
Old May 19, 2006 | 06:21 PM
Sideways's Avatar
Not to be misleading, there are 5 places you need to space so make up 5 spacers.
Old May 19, 2006 | 07:18 PM
gotswap's Avatar
If I understand you correctly, these "spacers" need to go under the fuel rail on the 10mm botl studs.
Old May 19, 2006 | 07:35 PM
Sideways's Avatar
There are 3 posts that you remove and put spacers under them. The other two spacers go below the brackets extending to the intake manifold.
Old May 19, 2006 | 09:27 PM
gotswap's Avatar
Gotcha, I know exactly what you are talking about.
jmardis
Jun 26, 2015 05:58 PM
s2k pike
Apr 6, 2007 04:09 PM
