Aftercooler question about air pump
Old Sep 30, 2012 | 10:13 AM
starrman's Avatar
Originally Posted by jdmdohcpower
about 2.5psi but I wanted to switch to tial bov and I just decided to change the set up. (my girl was driving me crazy so needed some time in the bat cave)
LOL...I understand the bat cave time! 2.5 isn't too bad...I would think that the air temp difference would make up for it. Would be interested to see the difference, did you dyno and will you dyno after the swap?
Old Sep 30, 2012 | 10:41 AM
starrman's Avatar
Originally Posted by Moddiction
Originally Posted by starrman' timestamp='1349011730' post='22047584
[quote name='Moddiction' timestamp='1349011002' post='22047570']
[quote name='starrman' timestamp='1348970136' post='22047081']
Just put a cap on it...might want to use a clamp as well. Just out of curiosity...why ditch the FMIC?
Fmic's are not a good setup to run for sc s2000's. 3-4 psi boost loss is common plus much worse throttle response.
Yeah it seems that as usual there are two arguments on this topic. I would expect boost loss, but would the colder iat's make up the difference? And why would there be a throttle response difference? I see iat's north of 150 and feel like the aftercooler is getting heat soaked with no way to cool off...especially on extended use or long drives. Thinking that on the track this will cause issues.
[/quote]
With a properly setup aftercooler/heat exchanger iats should stay pretty low. While driving mine usually don't go over 120 when 90+ outside.
Throttle response is a lot worse due to all the intercooler piping.
Fmic might work if your target boost is no more than 10 psi. To get that you would have to run a 12-14 psi pulley. 2.5-4 psi loss is normal for a fmic setup.
So if you want 12 psi with a fmic you will be overall ning the blower and making a lot less power since it will be blowing hot air.
[/quote]
Well when I get it back together Novi 1200 w/ 3.2" pulley is supposed to make 16psi... don't think I would mind losing some of that, but would certainly want the iat's to drop significantly. I just think that my aftercooler soaks and then I am screwed.
Old Sep 30, 2012 | 11:17 AM
Moddiction's Avatar
Former Sponsor
What size heat exchanger do you have? Are you talking about tracking the car it heatsoaks? I've never had mine heatsoak on the street with my setup.
Old Sep 30, 2012 | 11:20 AM
starrman's Avatar
Not sure what the overall size of the heat exchanger...but it is pretty big. It does not need to be tracked to heat soak...just cruising down the road.
Old Sep 30, 2012 | 12:46 PM
starrman's Avatar
Originally Posted by vduber
Remove it all and get a egr block off plate for the intake manifold
The plate for the manifold can be purchased from Puddy Mod Racing...same guy who builds the diffs. $17
Old Sep 30, 2012 | 01:43 PM
james0933's Avatar
Also, is your bov vented to the atmosphere or is it recirculated?
Old Sep 30, 2012 | 01:50 PM
Moddiction's Avatar
Former Sponsor
Is it the stock heat exchanger unit or an upgraded one? If stock then there's your issue.
Old Sep 30, 2012 | 02:32 PM
starrman's Avatar
No it is a Spearco...about half the size of the rad:
Old Sep 30, 2012 | 04:13 PM
jdmdohcpower's Avatar
Thats pretty much what I have. SOS front mount exchanger and this is the way Jeff Evans told me to go and for most people they like it. I want to see 10-11 psi on my qauge and with the FMIC that ='s overspinning the blower with a 3.0 pulley
Old Sep 30, 2012 | 04:20 PM
starrman's Avatar
Which blower do you have?
Sent from my Motorola Electrify using Tapatalk 2
