AHHH HELP!
Old Jun 28, 2008 | 06:03 PM
03silver2000's Avatar
Default AHHH HELP!
I am doing my 3mm headgasket and turbo install right now and I can not get the headbolts off! I dont know what size socket I should use or is there a special socket I need? I did the headgasket on my old integra and it was reg. bolts!
Someone lead me in the right direction Please!
Thanks Jordan
Old Jun 28, 2008 | 06:20 PM
blkwidow's Avatar
Why can't you get them off? Head bolts usually require some muscle and a pattern.
Old Jun 28, 2008 | 06:27 PM
what size socket do I use to remove them?
Old Jun 28, 2008 | 06:35 PM
SPECIAL-OPS-S2K's Avatar
it is a 14mm 12pt socket. You need a breaker bar. proably 1/2" drive... and a 12pt 14mm deep socket and you will have no problem. BE SURE to use the sequence when removing AND re-installing the head bolts as you will warp your head if you do not. Any questions, PM me.
Old Jun 28, 2008 | 06:37 PM
Thank You! Spec. Ops thats what I thought but cannot find one at my house right now all my tools are at work os ya. thanks
Jordan
Old Jun 28, 2008 | 06:41 PM
Jordan
no problem. I had the 14mm in a deep socket but it wasn't a 12pt so I just went out and bought one special. The 1/2" drive and breaker bar will make taking them off a piece of cake. Do you have the Honda Maintenence Manual?
Old Jun 28, 2008 | 06:48 PM
yah i have one but it didnt say the size, and unfortunatly all of my tools are at work except for a few extras and I dont have a 12 pt 14 untill tomorow il go pick one up, so this means now I am going to prolly do the fuel pump tonight and take off the headbolts tomorow.
Jordan
Old Jun 28, 2008 | 07:21 PM
ChefJ's Avatar
The manual is copyrighted so be careful what you say......
Old Jun 28, 2008 | 09:15 PM
Good point. Edited.
Old Jun 28, 2008 | 09:55 PM
Danks2k's Avatar
12pt 14mm ftw. Just make sure you take them out as prescribed in the manual. Good luck
