Air/fuel ratio safe?
I would prob get a wideband. Your tune is probably pretty close and good on a dyno. But it will help with cruising and idle if the ecu can read what's goin on. Bc currently it's all just based off of what was entered
You can turn up the base pressure if you have an FPR for id1000. I think the limit is about 600hp. You're prob close being on a MD
Thanks guys. I knew the ID1000 would be maxed out around 500whp. But that's why I have the dual 320lph pump surge tank.
Vitviper. What kind of dyno was your 580WHP run on ans any 1/4 mile trap speed?
