Another satisfied InlinePro customer
Apparently my stock clutch was already beginning to slip and so thats the reason why they kept the hp at 325. I plan on riding out this clutch until next year and then I'll make another big upgrade.
Originally Posted by slimjim8201,Mar 16 2008, 09:48 AM
This is the only issue that I was never able to sort out with my car.
The car would routinely stall if I was decelerating with minimal braking, with the transmission still in a high gear. When the revs reached 1,500-1,000 RPM, I'd disengage the clutch and shift to neutral for the stop. Upon disengaging the clutch, the engine would die. Not a sputtering stall either, just dead. No fuss, no vibration, no indication other than zero on the tach and no exhaust note. Strange...
If I put the car in the same scenario but did not ride the engine all the way down to idle (put the car in netural when the engine was still in the 2,000-4,000 RPM range), this never happened.
Sounds like a lot of fun! Congrats on your new found power! Hope your setup allows room for upgrade because im sure the itch for more power will be coming soon!
Originally Posted by JoeyBalls,Mar 16 2008, 09:50 PM
stock internals, as well as stock tranny?
Stock tranny fine
Stock diff / axles / driveshaft, fine assuming you don't launch your car
Originally Posted by JoeyBalls,Mar 16 2008, 09:13 AM
325WHP is Greddy type numbers
I know the upgrade potential is beastly though
Congrats on the Boost
Ben, glad you made it home safely. Ill be sending you a PM back in regards to the one you sent me letting me know you got home safely.
-Chris
Originally Posted by kutsujula,Mar 17 2008, 11:06 AM
very nice! how many psi?
Congrats!
Congrats!
I haven't got the chance to plug a laptop into the serial port either. I would guess around 8psi with the hp output.
