Any DIY for air pimp removal?
Old Mar 8, 2008 | 02:21 PM
kutsujula's Avatar
Default Any DIY for air pimp removal?
Anyone got any pics of the air pump removal? How is everyone getting around the water temp problem?
Old Mar 8, 2008 | 02:33 PM
Envied's Avatar
If you are referring to the water temp problem associated with the AEM EMS, a majority of the people are using Modifry's mod to make it work with the EMS. Just check out ECT link
Old Mar 8, 2008 | 03:34 PM
Tyraid2K's Avatar
no i just want to see the air pump gone
Old Mar 8, 2008 | 04:15 PM
PeanutButter's Avatar
Remove front bumper
Remove the bolts holding air pump on
Remove hoses from the air pump
Remove harness from air pump
Toss in garbage.
If anyone is wondering, the metal squiggly thing above the header is part of the air pump system.
That is where the fresh air is injected into the exhaust stream
Old Mar 8, 2008 | 04:25 PM
Kwando's Avatar
don't you need to cap something?
Old Mar 8, 2008 | 06:47 PM
Chiung's Avatar
Old Mar 9, 2008 | 06:25 AM
kutsujula's Avatar
THANKS
Old Mar 9, 2008 | 06:59 AM
JDM_EM1's Avatar
Where did you get that blockoff plate from? Did you make it?
Old Mar 9, 2008 | 08:17 AM
kutsujula's Avatar
inline pro or hardtopguy
Old Mar 9, 2008 | 12:59 PM
s2k_suprchrgd's Avatar
do you really need to take every thing out connected to the air pump??
is the blocking plate necessary??
