anyone has problems boosting past 7k on 1st gear?
Like title says. I've noticed on cool nights on 1st gear my S will boost hard and pulls all the way to 8k rpm but on hot days i'll stop at 7k rpm. Rpm will go to 8k but it wont pull as hard. 2nd 3rd 4th ... are always pulling hard to 6th gear.
weird... |
boosting in 1st gear?? Yeah mine feels like it stops pulling when the tires start spinning too...lol
Originally Posted by Charper732
(Post 24220326)
dunno, mine does seem to lack boost in 1st gear. Not sure if my tuner did boost by gear though. I rarely hit boost in 1st gear as all it does is spin the tires
How are you even getting traction in 1st...or 2nd for that matter? If youre hitting desired psi in all other gears im sure youre fine. But im all squirley in lower gears, even 3rd will break loose sometimes.
if its hot out your ems might be lowering boost based on iat compensation tables in your map. Maybe check there if youre experiencing lower peak boost in hot weather |
Originally Posted by Mijae007
(Post 24221385)
if its hot out your ems might be lowering boost based on iat compensation tables in your map. Maybe check there if youre experiencing lower peak boost in hot weather It might be something with my tune also from Erik's racing at 7psi. Then I had it retuned up to 11.5 psi in Bakersfield at vlspeed. The tuner from vlspeed said that he didn't change anything on the 7psi tune. He just added to it.. I do need to get another exhaust tho. I wanna go straight pipe and 3 inch dual exhaust. My invidia q300 sounds bad past 7k rpm..... |
I run 275/40/17 nitto and no boost by gear. My car made 650 whp and will make full boost in 1st if the tires could only hold it. It will hook second at this power level
Originally Posted by sleepencivic
(Post 24239412)
That's a nice setup. Can't wait to get my 3inch straight pipe and exhaust in then I can get e85 on my gtx3076 id1000 and fbm 340
