Anyone have vortech bov leak at high boost?
Old Apr 25, 2014 | 06:49 PM
Moddiction's Avatar
Former Sponsor
Default Anyone have vortech bov leak at high boost?
I'm re tuning shortly my v2 kit for around 16 psi. I currently have the max flow vortech bov.
Has anyone had this start leaking on them at higher boost?
I know they sell the Mondo bov which lists good for 12+ psi but wondering if anyone has found it necessary at these boost levels?
Old Apr 25, 2014 | 10:18 PM
s2000Junky's Avatar
A larger bov would be more Evac ability, which you generally need to keep from blowing off couplers or blowing out blower seals when the blower speed has increased from a smaller pulley change. The bov ability to hold pressure would be based on the quality of the bov, not its size. With that, ive never experienced failure of a bov to hold pressure at 20psi, not even the plastic Bosch recirc valve that comes in the comptech kit. The vt bov looks much more substantial a unit which I'd expect to be up to the task on holding boost, I do not know about its evac ability however, which would be more important. Maybe someone has experienced a bov failure I'm not aware of and they can chime in.
Old Apr 26, 2014 | 04:35 AM
Moddiction's Avatar
Former Sponsor
Yeah the Mondo can blow off a lot more. 550+cfm at 10 psi compared to the max flow race bov which is 320 cfm at 8 psi.
Old Apr 26, 2014 | 06:47 AM
Sideways's Avatar
Mine worked fine at 16 psi. I had some issues just past that pressure and got the Mondo BOV. Much louder now.
Old Apr 26, 2014 | 08:20 AM
Moddiction's Avatar
Former Sponsor
Ok good to know. Thanks! I'll try out the max flow race one I have first. Mines already really loud so the mondo would be pretty annoying I bet!
Old Apr 26, 2014 | 11:33 AM
Sideways's Avatar
Sort of like dragging a long heavy chain down the street. It's a loud way to imply I'm not on the throttle and It's just begging to be shut up with a full throttle run.
The Mondo BOV was a tight fit and I placed it just perfect so nothing touches.
Old Apr 26, 2014 | 01:25 PM
Moddiction's Avatar
Former Sponsor
Haha nice.
Do you have a picture with it installed?
Old Apr 27, 2014 | 07:54 AM
bruthaboost's Avatar
I have blown the couplers off as well with the vortech sc. I had a bead welded on the aftercooler portion coming off the SC outlet. Vortech didn't put one there originally.
Old Apr 27, 2014 | 08:22 AM
Moddiction's Avatar
Former Sponsor
How much boost are you running again on the vortech? And stock blower or did you upgrade things?
Old Apr 27, 2014 | 11:26 AM
I upgraded to the Si trim and am pushing 18 psi with a custom 7" crank pulley, 4.2" blower pulley, and shifting at 9k rpm. Also upgraded heat exchanger and went overboard with the water pump (meziere). I need to re-dyno though. I should be able to do it sometime this week.
