Anything else I would need for the CEL Fix?
Old Mar 13, 2008 | 05:39 PM
JoeyBalls's Avatar
Thumbs up Anything else I would need for the CEL Fix?
Going with the 70mm Test Pipe, what else would I need to do/buy to fix the potential CEL problem, or do I just screw the 02 sensor into the test Pipe?
http://www.evasivemotorsports.com/merchant...de=INVIDIA_TEST
Old Mar 13, 2008 | 05:42 PM
Spec_Ops2087's Avatar
Search non-fouler mod or maybe anti-fouler mod, that will "fix" the CEL from a testpipe.
Old Mar 13, 2008 | 05:44 PM
JoeyBalls's Avatar
thanks
Old Mar 13, 2008 | 06:59 PM
Enthralled's Avatar
or you can buy a T1R TP, it already comes with the CEL fix.
Old Mar 13, 2008 | 07:22 PM
Mr.Aqua's Avatar
I bought a 70mm invidia TP with the CEL fix for 95 shipped at iptuned.com
Old Mar 14, 2008 | 05:01 AM
JoeyBalls's Avatar
Ok so if I am understanding, once i get the 70mm Invidia Test Pipe with the CEL fix, I have to buy 2 18mm spark-plug antifoulers, drill one of them with a 1.5 in drillbit, screw the other antifouler into this one, and my 02 sensor into the non drilled one, then plug the whole thing into the test pipe???????
Old Mar 14, 2008 | 07:02 AM
devs2k's Avatar
i think you have to screw your o2 sensor into the drilled antifouler, thus the reason for drilling it.. but either way, you can easily tell when you have the drilled and un drilled antifoulers in front of you
Old Mar 14, 2008 | 07:06 AM
JoeyBalls's Avatar
so I guess the Invidia one, doesnt really have a CEL fix, it just has a bung to screw some anti-foulers into?. Why do I need to drill into one of the anti-foulers, is that so the other anti-fouler can fit in it?
Old Mar 14, 2008 | 07:10 AM
devs2k's Avatar
so the o2 sensor will fit into the antifouler
Old Mar 14, 2008 | 07:12 AM
JoeyBalls's Avatar
I see, and the bung on the Invidia Testpipe is not really to just screw in your 02 sensor (you would get a CEL), so you screw the anti-fouler in the bung with th Invidia?
