AP1 S2000 TURBO BUILD....
Old Jun 22, 2011 | 11:24 PM
s1ks2k.hi's Avatar
Default AP1 S2000 TURBO BUILD....
OK WELL I HAVE A 2000 HONDA S2000 AP1, JDM F20C
CURRENTLY I HAVE TITANIUM VALVE SPRINGS/RETAINERS, 3-WAY ANGLED VALVES, STAGE 2 CLUTCH.....PLANNING A TURBO BUILD, AND FINALLY DECIDED TO GO WITH:
PFAB STAGE 2 TURBO KIT
GARRETT GT35R
PFAB ELT TOP MOUNT MANI
PFAB 3" STAINLESS DOWNPIPE
PFAB Stainless Steel dumptube
TiAL 44mm wastegate
TiAL Q blow off valve
PFAB Stage 2 intercooler
PFAB Intercooler piping kit
PFAB High flow air intake & filter kit
PFAB Hardware kit
THATS WHAT COMES WITH THE KIT, AND ON THE SIDE I AM GETTING:
OKADA COIL PACKS
J'S RACING 70RR TITANIUM HEADER-BACK EXHAUST
1000CC INJECTORS
ALUMINUM RADIATOR
ALUMINUM OIL CATCH
ALUMINUM RADIATOR OVERFLOW
HONDATA K-PRO
255 WALBRO FUEL PUMP
AFTERMARKET MAP SENSOR
3MM HEADGASKET
ARP HEADSTUDS
ARP INTAKE MANIFOLD STUDS
ARP EXHAUST MANIFOLD STUDS
CONVERTING ALL LINES TO A/N FITTINGS W/ STAINLESS STEEL BRAIDED
PLEASE LET ME KNOW ANY INSIGHTS YOU MAY HAVE, I WANT A DECENT, RELIABLE TURBO BUILD....LOOKING FOR AT LEAST 400 WHP....LET ME KNOW IF THERE IS ANYTHING YOU WOULD RECOMMEND ME GETTING FOR THE BUILD.....THANKS
Old Jun 22, 2011 | 11:53 PM
S2K-F8's Avatar
Most here are going to tell you to ditch the 3MM headgasket....so I'll say it first, stick with the OEM headgasket.
Also, did I miss the aftermarket MAP sensor? You're gonna need one if running anything close to or over 10psi.
Clutch??
Fuel Pump??
Old Jun 23, 2011 | 12:13 AM
s1ks2k.hi's Avatar
yeah, i will be installing a walbro 255 fuel pump....can i make more power with a OEM headgasket, my only concern was too much compression
Old Jun 23, 2011 | 12:16 AM
s1ks2k.hi's Avatar
TOP MOUNT VS BOTTOM MOUNT VS FRONT MOUNT WHAT BETTER?
Old Jun 23, 2011 | 12:35 AM
S2K-F8's Avatar
Many (including myself) are making over 400hp on stock HG.
Old Jun 23, 2011 | 12:40 AM
s1ks2k.hi's Avatar
IS THAT THE JDM F20 BECAUSE I READ THEY HAVE A HIGHER C/R....I JUST WANT TO BE SAFE BUT HAVE GOOD POWER.....I WANT THE TOP MOUNT ONLY SO THE TURBO IS ACCESSIBLE BUT WILL IT BE BETTER TO GO WITH A DIFFERENT MANIFOLD
Old Jun 23, 2011 | 03:01 AM
Vi3tBoy's Avatar
I'm at 500+ on oem headgasket with arp studs.
What kinda fuel are you planning on using. Might want to look into a bigger pump b/c honestly they aren't much more. I think I paid 40 bucks more to have a FB pump rather than a walbro.
Also the 70mm exhuast might be on the small side. You won't stop at 400. You'll always want more. Don't want to upgrade on that expensive exhuast down the road
Happy boosting.
Old Jun 23, 2011 | 04:01 AM
StocS2k's Avatar
Ditch
3MM HEADGASKET
ARP HEADSTUDS
All those things are unnessary.
I would get the FB fuel pump itstead of the wally.
Yes you ok on the stock motor just don't open it.
Been proven over and over these motors hold up to boost.
Old Jun 23, 2011 | 04:58 AM
s1ks2k.hi's Avatar
ALRIGHT BRO IMMA HOLD YOU GUYS TO YOUR WORD NOW.....SO WHAT YOU THINK ABOUT TOP MOUNT, BOTTOM MOUNT, OR FRONT MOUNT?
Old Jun 23, 2011 | 10:46 AM
S2K-F8's Avatar
Originally Posted by StocS2k
Ditch
3MM HEADGASKET
ARP HEADSTUDS
I agree with most of this. From the OP's second sentence, it looks like he's throwing on a built head. If that's the case, then the ARP Headstuds are a good idea.
