arp headstuds for 8psi?
Old Dec 30, 2009 | 12:18 PM
08s2000CRbackinblack's Avatar
Default arp headstuds for 8psi?
i only plan on boosting 8psi on my stock engine with a t3/60-1. would that little of boost have any chances of strecthing the stock headstuds? should i get arp just incase or not worry about until i build the motor? thank you for any advice
Old Dec 30, 2009 | 01:21 PM
dsddcd's Avatar
If you are not taking off the head there is no reason to think about changing them. You won't lift a head at (3) times that pressure
Old Dec 30, 2009 | 01:26 PM
stock headstuds will hold 20 psi??? damn. well im painting my valvecover so i bought new gaskets and stuff and was gonna wait to do that if i was going to do headstuds. also 8psi would be the max boost you could run reliably on the stick motor correct? thinking maybe 10 but i dont wanna push it
Old Dec 30, 2009 | 01:27 PM
camuman's Avatar
LOL. 20+ can be done champ
just need a solid tune. s2k motor is godly.
Old Dec 30, 2009 | 01:29 PM
s2k dre's Avatar
Dont open the motor unless u have to. Thats a perfectly good motor.
Old Dec 30, 2009 | 01:54 PM
thanks everybody!!!!! now that i know im not gonna do the arp headstuds........ would 10psi be pushing it on stock compression and stock motor?
Old Dec 30, 2009 | 02:03 PM
mikeys2k's Avatar
its all in the tune..im running 450whp @ 12psi on a stock block,stock compression, looking to be running 15 next summer.. some run 20+ PSI no problems others blow at 10 (rarely)... just find a reputable tuner and a nice setup and you'll be fine... and like others stated head studs are not needed unless you open her up..
Old Dec 30, 2009 | 02:16 PM
deathsled's Avatar
god...we just told you 20+ is fine on a stock motor
Old Dec 30, 2009 | 05:46 PM
S2SEXY's Avatar
hes asking about compression not the bolts the second time.10 psi will be fine
umair
Oct 21, 2017 08:57 AM
McFab
Mar 17, 2013 03:48 PM
sbrodacz
Apr 29, 2009 11:46 AM
kutsujula
Aug 6, 2008 01:55 PM
slammo
Feb 24, 2006 06:09 PM
