ARP Headstuds Thread
Old Apr 10, 2012 | 07:22 AM
o'malley_808's Avatar
Default ARP Headstuds Thread
Hopefully this thread can put to rest the discrepancy in ARP studs for those of us blowing HGs
Please post the following:
Headgasket:
Moly lube or oil:
Torque spec used:
Sequence/torque method:
Re-Torque (Yes or no):
New Studs or re-used:
WHP:
PSI:
Miles lasted:
Hopefully that list should cover it!
Old Apr 10, 2012 | 07:29 AM
Headgasket: IP 3mm
Moly lube or oil: ARP moly
Torque spec used: 85 ft/lbs
Sequence/torque method: Honda service manual
Re-Torque (Yes or no): no
New Studs or re-used: used
WHP: 478
PSI: 21
Miles lasted: 5000
Old Apr 10, 2012 | 07:31 AM
Headgasket: SCE Copper 2mm with copper spray
Torque spec used: 90 ft/lbs
Re-Torque (Yes or no): Yes (each bolt turned an extra 1/8 turn)
WHP: 600whp
PSI: 23
Miles lasted: 8000
Old Apr 10, 2012 | 09:37 AM
DFWs2k's Avatar
Headgasket: oem
Moly lube or oil: some assembly oil type stuff had laying around
Torque spec used: 100 ft/lbs (90-100, cant remember exactly, will ask buddy who works on car w me)
Re-Torque (Yes or no): ? Tightened in 3 different steps
WHP: 480whp
PSI: 17
Miles lasted: 15-20k
Sent using free Tapatalk - Android FTW
Old Apr 10, 2012 | 09:49 AM
passmans2kny's Avatar
Headgasket: ip 3mm
Moly lube or oil: moly lube
Torque spec used: 90ft/lbs
Re-Torque (Yes or no): 30/60/90 no retorque
New Studs or re-used: new
WHP: 535
PSI: 17
Miles lasted: 4000
blew between cyl 2-3
Headgasket: oem
WHP: 480whp
PSI: 13
Miles lasted: 3000, did not blow, redid my set up
new set up, fbm L19 head studs 100ft/lbs on 30 psi oem hg, no issues
Old Apr 10, 2012 | 09:51 AM
05TurboS2k's Avatar
Headgasket: OEM
Moly lube or oil: ARP (new improved assembly lube from ARP)
Torque spec used: 95ft/lbs on digital tq wrench accurate to 2%
Sequence/torque method: 33/66/95 Factory Sequence as shown.
Re-Torque (Yes or no): No
New Studs or re-used: New
WHP: 450 prior / 700+ new setup awaiting first run
PSI: 8psi / 15psi / xxpsi
Miles lasted: Didn't blow prior / N/A (not tested yet)
Great thread btw! I'll continue to update with results good and bad.
Old Apr 10, 2012 | 11:49 AM
teamvalorracing's Avatar
Headgasket: stock
Sequence/torque method: FSM(chased,cleaned, blew out block threads before install)
WHP: been as high as 415, currently at 373
PSI: 9.5-18
Miles lasted: 25,000 and counting
Old Apr 10, 2012 | 02:20 PM
spectacle's Avatar
http://www.youtube.com/watch?v=6-XXVk_vwKw
Old Apr 10, 2012 | 02:23 PM
05TurboS2k's Avatar
^ Nice post.
This should be stuff thats 101 basic for everyone on this forum arguing about these topics.
This is why I cringe when I ask what someone used to install their ARP studs with and they're unsure or used what they happen to have without calculating the extra torque needed to achieve proper clamping aside from repeatability which obviously changes greatly.
Old Apr 10, 2012 | 03:14 PM
nice video, everyone should see this
