ATI vs FLUIDAMPR
Old Dec 25, 2013 | 06:49 AM
jpetch05's Avatar
Default ATI vs FLUIDAMPR
Hey guys. I know a lot of you have been back and forth on the fluidampr post talking about some pros and cons. The more I read the more I am back and forth.
Many on that post to say that fluidampr is superior, and many posts elsewhere online say that ati is superior. Obviously if you're a vendor you're going to push your product.
Here is a page on the ati damper from Laskey. http://www.laskeyracing.com/shop/harmonics.htm
They have a comparison to the fluidampr.
I originally wanted the fluidampr, but now I am undecided.
Insights ?
Old Dec 25, 2013 | 09:47 AM
jpetch05's Avatar
I have also heard of cars coming apart after switching to a fluidampr. No s2000s but from other forums.
It's confusing cause this forum made me want the fluidampr
Old Dec 25, 2013 | 11:04 AM
99SH's Avatar
When I was doing my research I was told that ATI did not design their damper specific for the s2k. They changed the snout of a K series damper and made/marketed it as a s2k damper. I had a lot of discussions with URGE and Fluidampr directly with test data on a s2k specifically. They did do their homework and due diligence. If you're heart-set on buying a damper, get the Fluidampr.
Old Dec 25, 2013 | 01:06 PM
wy2slow_z's Avatar
hey man. I believe there are a few high hp guys running both. I know neema has the urge. might check
Old Dec 25, 2013 | 01:09 PM
redboost10's Avatar
that was up until about a year ago, now ati has a s2000 specific damper
Old Dec 25, 2013 | 01:28 PM
jpetch05's Avatar
What's your take red, I always value your opinions
Old Dec 25, 2013 | 02:28 PM
redboost10's Avatar
I've used both...bearings always look great when inspecting/freshening up the motor in the winter. Either is an advantage over oem. I believe they have similar price tags as well.
Old Dec 25, 2013 | 02:56 PM
jpetch05's Avatar
How do you feel about the Laskey link I sent. Possible bias data ?
So no bearing issues at all ? Hmph this could be a hard choice then :|
Old Dec 29, 2013 | 08:51 AM
jpetch05's Avatar
Anyone
Old Dec 29, 2013 | 09:15 AM
B5254T4's Avatar
I´ve been in the same spot but decided to go OEM this time, seen a lot of high hp guys using OEM and can´t find enough reasons to spend the extra cash right now.
I mean, if the OEM one can keep the bearings fresh for 100.000 miles and more on a really well designed 9000rpm engine I´m sure it will do a good job on a low mile weekend racer for a while.
