Back wheel still vibrating under load
Old Nov 27, 2010 | 06:31 AM
JoeyBalls's Avatar
Thumbs down Back wheel still vibrating under load
This normal if the divot is large enough?
Guess I have to buy new CV Joint cups, FML
Old Nov 27, 2010 | 06:45 AM
broke 20's Avatar
Definitely sounds like cv joints. You could just use your current ones as a core trade in on some new ones, I hate rebuilding those things lol
Old Nov 27, 2010 | 09:12 AM
Dreaming_S2k's Avatar
Just switch the CV joint cups from side to side. Put the right one on left, and vice-versa. Keep the spacers in place as well.
Of course if you've done this already then...yeah.
Old Nov 27, 2010 | 04:35 PM
JoeyBalls's Avatar
^ Did that about a year ago
Old Nov 27, 2010 | 06:09 PM
bluemetals2k's Avatar
axle buckets
Old Nov 27, 2010 | 08:38 PM
joes sled 2000's Avatar
New inboards for you .
Old Nov 29, 2010 | 06:19 PM
Jacko's Avatar
So what are your plans? are you going to replace with OEM or aftermarket
Old Nov 29, 2010 | 10:53 PM
s2000Junky's Avatar
You can run the cups 4 different ways. Original, original with spacers, swap cups side to side with no spacers and then run the spacers again.
Ride height fluctuation would make a difference also.
My half shafts are the only thing left original drive train wise on my car with almost 200k on them.
Old Nov 30, 2010 | 05:10 PM
JoeyBalls's Avatar
hmmmmmmm I did swap them a year or so back, was good until a few weeks ago, then I added spacers and helped a little but still vibrating, should I try and swap them back to original and use the spacers and see if that helps?
I guess its worth a try rather then buy new cups
Old Nov 30, 2010 | 05:46 PM
s2000Junky's Avatar
Yeah I would, it couldn't hurt to try your last option. Your cups and prop ends might be extra hashed from all that trq
