Backfiring?
Old Dec 24, 2010 | 10:20 PM
Booztin's Avatar
Default Backfiring?
Had my car tuned this past summer for my current setup. I noticed after all said and done , I took it on the highway a few times and got on it and it was backfiring. Was told it was normal and as long as my a/f looked fine witch it did then its fine.
Well lately I've been kinda questioning it. Its colder out and my car was tuned in the summer and from what I understand the colder the weather the higher the chance of this happening becomes because the a/f ratio leans out from having denser air. (at least i think).
Anyhow , the question is how normal is it and is it bad? Any time I get on it usually 1-2 backfires around 8-9k before I shift almost every shift and if im at 8-9k or so and just let my car decelerate while in gear it backfires 1-3 times as its decelerating if i put it in neutral and just let it decelerate, nothing happens.
Here's my setup if it helps
1220sl comptech s/c 10 psi pulley installed
5zigen header
70mm invidia tp
70mm invidia single exhuast
1000cc injectors
tuned on a aem v.2
Old Dec 25, 2010 | 07:46 AM
dsddcd's Avatar
Sounds like you are hitting boost cut, in the winter the denser air helps increase the boost on a supercharged car. I would pull up your map and see what PSI you are running and check where the boost cut was entered.
Good luck
Old Dec 25, 2010 | 09:36 AM
Booztin's Avatar
[QUOTE=dsddcd,Dec 25 2010, 11:46 AM] Sounds like you are hitting boost cut, in the winter the denser air helps increase the boost on a supercharged car.
Old Dec 25, 2010 | 10:34 AM
Moddiction's Avatar
Former Sponsor
Backfires are usually from running rich not lean in between shifts or when letting off the gas.
What afr's are you seeing?
Old Dec 25, 2010 | 07:07 PM
IAmTheRealAsif's Avatar
Technically its called after fire
raneyboo
Jul 11, 2011 03:32 AM
kaissi
Dec 25, 2009 04:53 PM
cougar hunter
Aug 19, 2008 09:30 PM
thesilverbullet
Feb 22, 2008 05:42 PM
stifelinS2G
Mar 6, 2007 08:35 AM
