Base Fuel Pressure
Old Apr 27, 2009 | 04:52 AM
siadam's Avatar
Default Base Fuel Pressure
I don't have my gauge installed quite yet, so I don't know what the pressure is.
It's a stock fuel setup sans a Walbro 255lph pump.
Old Apr 27, 2009 | 04:59 AM
AusS2000's Avatar
Stock fuel pressure in AP1s is 47-54psi static. Not sure if it is different in later models.
Old Apr 27, 2009 | 05:37 AM
camuman's Avatar
its the same in the ap2 until 06-07 returnlesss fuel system. then i thin it went up.
Old Apr 27, 2009 | 05:41 AM
siadam's Avatar
Ok, cool. Thanks guys, appreciate the quick answers.
Old Apr 27, 2009 | 05:45 AM
siadam's Avatar
One quick note, is this fuel pressure base? Or is it static as you mentioned with the FPR vac line disconnected?
Old Apr 27, 2009 | 05:54 AM
camuman's Avatar
static fpr vac line disconnected.
Old Apr 27, 2009 | 06:08 AM
siadam's Avatar
Cool, on a side note, what is the base pressure w/the line connected for my own knowledge?
Old Apr 27, 2009 | 06:10 AM
Revenge's Avatar
same as walbro? one think I think I learned about the walbro pump when it gets hot it makes noise?
Old Apr 27, 2009 | 06:25 AM
siadam's Avatar
No, it's a Walbro.
They shouldn't really get hot..if thats the case, you are running your fuel to low.
I try to stay around 1/2 a tank @ the least.
Old Apr 27, 2009 | 06:51 AM
drhess06259's Avatar
I also would like to know what it should be running with the vac line connected. I run it at 40 is that to much or not enough?
