Battery recommendation
Old Aug 1, 2009 | 10:36 AM
blueap2's Avatar
Default Battery recommendation
What battery do you guys recommend? I live in socal so cold weather is not a problem. I am also not running a huge audio system that needs tons of power...Thanks!
Old Aug 1, 2009 | 12:21 PM
s2guru's Avatar
i'm running the Deka ETX20L ( deka: is the maker of braille batteries )
Deka ETX20L = braille B2015
deka: $75 shipped
braille: $165 shipped
Very small battery with a lot of juice. I'm running alpine head unit, kappa perfect speaker x 4 + amp with no problems.
Old Aug 1, 2009 | 04:20 PM
blueap2's Avatar
this is not a dry cell is it?
Old Aug 1, 2009 | 09:50 PM
dsddcd's Avatar
I have been very happy with my Optima
Old Aug 3, 2009 | 02:38 PM
EngineerX's Avatar
Not technically, but it behaves like one.
Eastern Penn uses AGM (absorbed glass mat) Google it.
Deka = Braille, but warranty length is not the same, but @ half the price I bought one, no brainer , got the ETX16, plenty of juice.
tested
http://forums.vwvortex.com/zerothread?id=2353060&page=1
a good place to buy them from - cheap & fast delivery
http://www.tristatebattery.com/index...Path=36_96_235
Better to get the 16 or 18, better capacity and just 4 lbs heavier than the ultralight units. Take a dump and drain the lizzard, that should get you 4 lbs off.
One thing to keep in mind with these batts, including the Optimas and Odysseys is that you need a charger that is capable of supplying 14.5V or more to avoid premature death, research "sulfation" for deep-cycle batts.
I learned about it when my Odyssey died after using a standard charger. Luckily I got it warrantied by Odyssey new batt- no charge (un-pun unintended) I immediately bought a CTEK batt charger - pricey ~ $120 but keeps the PC925 in my Subaru and the ETX16 in the S2000 nicely charged and in top shape.
http://www.amazon.com/CTEK-US7000-Lead-Aci...r/dp/B000FRLO9Y
Old Aug 3, 2009 | 02:48 PM
blueap2's Avatar
lol, thanks man!
Old Aug 3, 2009 | 02:49 PM
EngineerX's Avatar
No Prob - I added more info - see above
Old Aug 3, 2009 | 02:52 PM
blueap2's Avatar
are u using this battery as well?
ha ha, i guess u are....does it need to be vented or anything since im planning to put it in the trunk. I'm assuming since its non-spillable i can also mount it on sideways right?
Old Aug 3, 2009 | 07:39 PM
EngineerX's Avatar
Yep- I got the ETX16
it can be mounted any which way you want
More info :
Regarding an ETX18 cranking power:
It should crank engine very well -this is my assessment based on my use of a ETX16, a smaller batt.
As long as you run good wire
You want to use 0-gauge wire and good ground to a couple of locations one to chassis and another 0-gauge wire to engine grounding point
the ETX18 shows at 330CCA @ 0*F
the ETX16 275CCA
my ETX16 cranks the engine just like a regular batt.
I have an Odyssey PC925 on my Subaru and it's rated @ 380 @ 32*F. It's mounted in the trunk.. cranks 2.5L engine with no problem
You just want to make sure your wiring is good
I would recommend 0gauge wire direct to starter- same location that the wire from the stock batt goes to the starter- just follow that wire.
Also the ETX16 is pretty small, you can mount it @ 90 degree rotation from stock orientation, right up against the firewall. You just take out the batt tray and make a couple of flanges from L-shape aluminum angles. Works very well. I'll try and take pics and post them here or maybe on one of my threads.
You can use Odyssey batt posts, also available @ Tristate or Summit.
video of engine crank/start
http://subaru-wrx-sti.com/web/S2000/Deka_Batt_Crank.wmv
here's some pics for comparison
stock batt + batt tray weight
Deka ETX16 weight, save 10 lbs!
I'm posting this on the thread for everyone's benefit.
hope that helps
Old Aug 6, 2009 | 06:51 AM
tudorart's Avatar
anybody know of a maintenance free battery under 150 and better/lighter than oem? thanks
