Battery Relocation and Fuse Box Relocation
Old Aug 15, 2009 | 07:53 PM
JoeyBalls's Avatar
Default Battery Relocation and Fuse Box Relocation
Ok, Along with the Methanol Injection Kit I will be removing my battery to the trunk, and I will also be putting my Fusebox in the location of where the Washer Tank is (in the fender), the search is to little avail, does anyone have any good write ups on these to re-locations?
Old Aug 15, 2009 | 08:03 PM
dsddcd's Avatar
I can't help with the fuse box but here is the best Battery DIY
https://www.s2ki.com/forums/index.php?showt...&#entry16651796
Old Aug 15, 2009 | 08:16 PM
JoeyBalls's Avatar
thanks
Old Aug 15, 2009 | 08:59 PM
boostedf22c's Avatar
https://www.s2ki.com/forums/index.php?showt...0&#entry9000743
Old Aug 15, 2009 | 10:04 PM
donaldmejr's Avatar
so if im correct...in order to relocate the fuse box on MY08 I wont have to cut any wires? If so then I will be doing this when I get home.
Old Aug 16, 2009 | 06:08 AM
I had to cut quite a few, extend some, it was a day project when it was all said and done. Not that hard, but a bit time consuming. I also did the AC relocation lines as well why I was at it.
Old Aug 16, 2009 | 08:35 AM
donaldmejr's Avatar
Yeah Im just not wanting to cut up MY08 just yet
Old Aug 16, 2009 | 12:08 PM
juntuned's Avatar
anyone ever relocate the fuse box in place of the passenger airbag? This would leave it accessible to switch out fuses simply by removing the airbag cover. I think I might try this.
Old Aug 16, 2009 | 12:20 PM
2QYK4U's Avatar
That was my intention. Had that area completely cleared out and ready...but unfortunately quit the build otherwise it would have been done. Best location IMO.
Old Aug 16, 2009 | 12:34 PM
Soul Coughing's Avatar
i would personally relocated the fuse box under the passenger area, above the footwell. You then don't lose the airbag and don't need to remove the fender to access the fuses.
