Best supercharger setup
What is the best SC setup for stock internals and pump gas?
also, would a lightweight flywheel like say.... an AP1 flywheel in an AP2 (or maybe the CT) be helpful or hurtful on a supercharged S2K?
I would be biased but would say Vortech. The Vortech has made the most power for stock internals and pump gas. KW is a good kit though if you are looking for somewhere in the 300's. Although, I do not think they have received their CARB status as of yet. I have the comptech flywheel and love it. That sig looks very ricey.
Originally Posted by Enthralled,Sep 1 2008, 12:46 PM
depends on what you need it for. is it mainly for street use? we have several SC kits to choose from. what is your budget?
i thought a SC setup would be simpler and cheaper than turbo, but will it perform to the same degree in a straight line?
Originally Posted by TelosHedge,Sep 1 2008, 01:28 PM
you won't make the same torque curve as you would with a turbo, but mid 12's are definitely do-able. you will likely need to run more boost on a centrifugal kit to get there, but thats not hard
my only worry is damaging the motor on stock internals, or blowing my differential/axles/drive shaft.
