Big Spool sound diffrence GT30R vs. GT35R
Old Dec 3, 2007 | 05:37 PM
flexer's Avatar
Default Big Spool sound diffrence GT30R vs. GT35R
OK,
So I had a GT30/71R mini-me lovefab set-up, and it was the first time I heard a turbo sound the way it did. It didn't have that high pitched whistle I usually hear in a turbo car, but really I just heard it SUCKING AIR. Maybe sometimes you could hear it a little, but not really. Most I ever ran on it was 10 psi of boost, but I ran low boost like that on my other cars , and the turbo whine was very pronounced and loud, but I was running diffrent turbo's on those cars.
SO>......
Who has owned or heard both? Does the GT35R sound a lot different? Anyone have a sound clip or video of there car with a GT35R?
Or post a vid or sound clip of another turbo that has a very pronounced whine and list the turbo.
J. R.
PS. Yes this is a lame topic, but I am currious as wo why some turbo's make the whine and others don't.
Old Dec 3, 2007 | 06:23 PM
Terror's Avatar
The GT30R (GT3076R) has a somewhat High Pitched whistle, where as the GT35R has what you described as "Sucking Air".
Edit:
GT3076R Video:
http://youtube.com/watch?v=AYz14Hqhaq8
GT35R Video:
http://youtube.com/watch?v=5-jdY4c26qg (I know it's not an S2000, but it's all I could find on short notice)
Old Dec 3, 2007 | 06:29 PM
flexer's Avatar
Edit:
GT3076R Video:
GT35R Video:
REALLY. I heard its the opposite. The 35R whistles, and the 30R just sucks air.
J. R.
Old Dec 3, 2007 | 06:58 PM
slimjim8201's Avatar
It depends on a lot of factors. The sound pitch of the turbo is mostly related to the rotational speed. Higher speed, higher pitch. I don't think we can just classify GT30s and GT35s and say one will sound different than the other. You have to account for not only the turbine side (the 30/35 part) but the compressor side as well. I believe difference in the compressor size, trim, housings will have a big impact on sound. A larger compressor doesn't need to spin as quickly to move the same amount of air as a smaller compressor.
Look at a centrifugal supercharger. It's just a large compressor wheel that only spins to 45,000-50,000 RPM. Typically, turbo compressors spin to 90,000-120,000 RPM.
There are so many noises going on when I'm in full throttle, I don't think I can really hear my turbo spinning at all. When I slowly roll into and out of throttle, I can certainly hear the turbo spool up, but once it gets to a certain speed, it just sounds like a jet engine...
Here's a video of mine. At the beginning I rolled into boost lightly a few times but I think the whooshing sounds are mostly gas escaping the BOV since there I wasn't in WOT. You are hear the turbo "respool" after each shift, but it spools so fast, it all just sounds like air.
Turbo Sounds
Old Dec 3, 2007 | 07:53 PM
Spec_Ops2087's Avatar
It doesn't help that we use external wastegates which muffles out ~75% of the turbo noise.
Old Dec 3, 2007 | 10:05 PM
lowrthnu2.2's Avatar
...... all i hear is wastegate noise
Old Dec 3, 2007 | 10:18 PM
Peter@ISP's Avatar
Former Sponsor
heard both. the reason why gt30s are louder is because of the anti-surge housing design. GT35r we see usually has design similar to hks turbos. you can get the anti-surge housing like gt30 for gt35r from garrett.
Old Dec 4, 2007 | 04:23 AM
PeanutButter's Avatar
My GT3076R had the whistle sound.
Old Dec 4, 2007 | 05:45 AM
flexer's Avatar
What housing A/R did you have, and what boost level?
J. R.
Old Dec 4, 2007 | 06:31 AM
Terror's Avatar
I've only heard a GT3076R .63A/R and one was on a D16 and one was on an EJ20. Both had the somewhat loud whistle.
Here is another video (This is the Civic I was talking about):
http://youtube.com/watch?v=5bqYJMXjtqw
