Blow off valve on a Comptech?
Old May 13, 2007 | 10:55 PM
CTECHs2k's Avatar
Default Blow off valve on a Comptech?
Hi, I have a Comptech supercharger but no AfterCooler. I was wondering if I can add a adjustable blow off value to it, cause I know the air is being recycled. And would it make it better?
Thanks!
Old May 13, 2007 | 11:27 PM
AusS2000's Avatar
Depends on your definition of better.
If you mean "Will it make fully sik PSSSSFFFFTTT noise?" then sure, but not like a Turbo BOV. The Comptech is always venting except when at WOT. So it will wheeze all the time and give a bit of a PSSSSHHH when you go hard then release.
Try the TurboSmart Kompact. fits inplace of the Bosch unit and has a cap for the intake tube. You'll need a supercharger spring too for the low boost level.
Old May 13, 2007 | 11:57 PM
lend_type_R's Avatar
Aus, are they loud compared to other type of BOV that is being installed to an SC?
Old May 14, 2007 | 12:09 AM
AusS2000's Avatar
Ummm, not sure really. Not familiar with others. If you do a search for 'TurboSmart Kompact' you'll see a video of mine with some sound.
Old May 14, 2007 | 12:16 AM
cant find any. can you put a link?
Old May 14, 2007 | 12:22 AM
AusS2000's Avatar
You're kidding right? Just found it in about 10 seconds flat.
Old May 14, 2007 | 12:28 AM
sorry but i cant. if you could help i would really appriciate. i tried google video and youtube. im probably searching on wrong site.
Old May 14, 2007 | 01:11 AM
AusS2000's Avatar
Try searching this one.
Old May 14, 2007 | 07:10 AM
stphotographer's Avatar
To whore out these bad pictures of my engine bay again:
GoFastBits Stealth FX .Is it better than the stock Bosch unit? Yes and no. It makes a cool sound, I had it on the dyno and it was pretty loud from the outside. Probably doesn't leak like the Bosch unit if your running more than stock boost. If I had to do it over again I'd upgrade to a beefier Bosch unit from a Porsche or an Audi.
This has been covered over and over again. Please search.
Old May 14, 2007 | 07:22 AM
ChefJ's Avatar
BOV on a supercharger = SHOW OFF VALVE no real use besides rice
