Blucky87's build thread
Ok here's my build... plan on finishing it and getting it tuned in June. I used to have a CTSC.. now i have a ptuning kit. sorry for iphone pics... https://www.s2ki.com/s2000/public/st...ault/frown.gif
https://farm6.static.flickr.com/5254...7bb6e787_b.jpg What made me start the build was the bolt that my friend is pointing at broke in half and car ran like crap and there was NO WAY to get the threaded half of the bolt out and the hole it went in was worn out of round. only thing to do was get a new head. I was leaving for Iraq in about 2 months when this happened and the S was my DD. I picked up a 1993 Prelude Si (4 wheel steering, DOHC H23a1) with 170,000 miles to use as my beater. https://farm6.static.flickr.com/5259...b940f763_b.jpg Ordered a PTuning kit while deployed with the introductory pricing, had them put an Engine Gas Temperature sensor on each runner of the manifold. https://farm6.static.flickr.com/5059...3f60ba03_b.jpg GTX3076R turbo https://farm6.static.flickr.com/5058...bed6fc73_b.jpg Still needs a turbine housing.. everyone is sold out of the .82AR... may go 1.06 if I can't get one in time https://farm6.static.flickr.com/5140...000d4507_b.jpg Ptuning 3" dual exhaust https://farm6.static.flickr.com/5018...e2b037a0_b.jpg Okada projects ignition coils https://farm6.static.flickr.com/5176...aa1eb0b4_b.jpg Turbosmart WG and BoV https://farm6.static.flickr.com/5180...f17855be_b.jpg Koyo Radiator https://farm6.static.flickr.com/5092...27f34eb3_b.jpg EGT sensors https://farm6.static.flickr.com/5292...b78d7e37_b.jpg Devil Sown Meth kit.. going direct injected into the intake manifold runners https://farm6.static.flickr.com/5055...12eca8e9_b.jpg InlinePRO fuel rail https://farm6.static.flickr.com/5014...229903f0_b.jpg ID1600 Injectors https://farm6.static.flickr.com/5057...f1817b0a_b.jpg Precision Power 365cs component speakers https://farm6.static.flickr.com/5134...a1f546c0_b.jpg AEM Fuel pressure regulator https://farm6.static.flickr.com/5094...e371cf91_b.jpg https://farm6.static.flickr.com/5171...d01f3103_b.jpg Laskey Racing built F22c engine 9:1 CR 87mm bore Total parts list: Laskey racing shortblock, 9:1cr with 87mm bore CC Cylinder heads built head, port and polish with supertech valvetrain PTuning turbo kit ATP incolnel wrapped turbo manifold GTX3076r turbo, 1.06 AR Injector Dyamics 1600cc fuel injectors Okada Projects ignition coils Fullblown Dual fuel pump hanger, -8an feed -6an return 2 Walbro 255lph fuel pumps 4 EGT sensors, 1 on each cylinder Puddymod stg 2 differential PTuning 3" dual exhaust InlinePRO fuel rail Devil Sown direct injection meth kit Turbosmart Blow off valve Turbosmart Hypergate 45mm wastegate MAC boost solenoid ARP head studs PTuning Oil cooler Denso IK24 spark plugs Koyorad radiator SoS Speed engineering directional vane rotors with OEM pads AEM series 2 ECU, 30-6052 Precision power 365cs component speakers Rockford Fosgate Punch P3 12" sub Rockford Fosgate Power 600 and 400 watt amps Innovative 75a motor and tranny mounts AEM Fuel pressure regulator Exedium differential collars CC lightweight flywheel Brad Penn 15w-40 motor oil i'm sure I left some stuff out.. will update as new info comes Goal is to max out the turbo and see what that gets me to with 93oct. possibly get an e85 tune also..... Any ideas what I might make? |
sick build, deep pockets, good luck this thing will dominate :thumbup:
Nice! Its great to see so many different turbo builds these days! What year is your s2k?
2004, picked it up october 2009 with 65k miles. IMHO GPW and NFR are my fav colors. drove from arkansas to alabama to pick it up
Very nice build so far! Looks a lot like my build...In for results
600whp+ do it :D
Originally Posted by EternalLx
(Post 20379474)
600whp+ do it :D
Weak :thumbdn:
Originally Posted by jonbar87
(Post 20383975)
Weak :thumbdn:
:confused: |
$$$$ :D Should be well worth the money spent :thumbup:
