Blucky87's build thread
Old Mar 19, 2011 | 01:27 PM
Blucky87's Avatar
Default Blucky87's build thread
Ok here's my build... plan on finishing it and getting it tuned in June. I used to have a CTSC.. now i have a ptuning kit. sorry for iphone pics...
What made me start the build was the bolt that my friend is pointing at broke in half and car ran like crap and there was NO WAY to get the threaded half of the bolt out and the hole it went in was worn out of round. only thing to do was get a new head.
I was leaving for Iraq in about 2 months when this happened and the S was my DD. I picked up a 1993 Prelude Si (4 wheel steering, DOHC H23a1) with 170,000 miles to use as my beater.
Ordered a PTuning kit while deployed with the introductory pricing, had them put an Engine Gas Temperature sensor on each runner of the manifold.
GTX3076R turbo
Still needs a turbine housing.. everyone is sold out of the .82AR... may go 1.06 if I can't get one in time
Ptuning 3" dual exhaust
Okada projects ignition coils
Turbosmart WG and BoV
Koyo Radiator
EGT sensors
Devil Sown Meth kit.. going direct injected into the intake manifold runners
InlinePRO fuel rail
ID1600 Injectors
Precision Power 365cs component speakers
AEM Fuel pressure regulator
Laskey Racing built F22c engine 9:1 CR 87mm bore
Total parts list:
Laskey racing shortblock, 9:1cr with 87mm bore
CC Cylinder heads built head, port and polish with supertech valvetrain
PTuning turbo kit
ATP incolnel wrapped turbo manifold
GTX3076r turbo, 1.06 AR
Injector Dyamics 1600cc fuel injectors
Okada Projects ignition coils
Fullblown Dual fuel pump hanger, -8an feed -6an return
2 Walbro 255lph fuel pumps
4 EGT sensors, 1 on each cylinder
Puddymod stg 2 differential
PTuning 3" dual exhaust
InlinePRO fuel rail
Devil Sown direct injection meth kit
Turbosmart Blow off valve
Turbosmart Hypergate 45mm wastegate
MAC boost solenoid
ARP head studs
PTuning Oil cooler
Denso IK24 spark plugs
Koyorad radiator
SoS Speed engineering directional vane rotors with OEM pads
AEM series 2 ECU, 30-6052
Precision power 365cs component speakers
Rockford Fosgate Punch P3 12" sub
Rockford Fosgate Power 600 and 400 watt amps
Innovative 75a motor and tranny mounts
Exedium differential collars
CC lightweight flywheel
Brad Penn 15w-40 motor oil
i'm sure I left some stuff out.. will update as new info comes
Goal is to max out the turbo and see what that gets me to with 93oct. possibly get an e85 tune also..... Any ideas what I might make?
Old Mar 19, 2011 | 01:56 PM
passmans2kny's Avatar
sick build, deep pockets, good luck this thing will dominate
Old Mar 19, 2011 | 02:12 PM
GrandMasterKhan's Avatar
Nice! Its great to see so many different turbo builds these days! What year is your s2k?
Old Mar 19, 2011 | 02:15 PM
Blucky87's Avatar
2004, picked it up october 2009 with 65k miles. IMHO GPW and NFR are my fav colors. drove from arkansas to alabama to pick it up
Old Mar 19, 2011 | 03:20 PM
s2000442's Avatar
Very nice build so far! Looks a lot like my build...In for results
Old Mar 19, 2011 | 11:34 PM
EternalLx's Avatar
600whp+ do it
Old Mar 19, 2011 | 11:42 PM
Blucky87's Avatar
Originally Posted by EternalLx
600whp+ do it
Id love too! im sure the spool would be amazing and the car would have so much mid range torque ppl wouldn't think it was a honda
Old Mar 21, 2011 | 02:24 PM
jonbar87's Avatar
Weak
Old Mar 21, 2011 | 03:27 PM
daicacharco's Avatar
Originally Posted by jonbar87
Weak
Old Mar 21, 2011 | 04:33 PM
o'malley_808's Avatar
$$$$ Should be well worth the money spent
