Boomslang harness
Ok. My emanage boomslang harness was mispinned for vtec. There were 2 yellow wires that were in the wrong spots. I pait 180 dollars for this harness and 150 dollars at the tuners to have them figure out what was wrong with it. Now I am throwing a code 1259 and don't know why?? Should I just mail this thing back to them and have them send me another one?? Should I make a more prominent post about boomslang and the possibility that there harness is not perfect. 180 bucks for some wires and they should have it dead on.
are you getting a Vtec check engine light with a VSS check engine light???
This is an old problem that I experienced when the ULT first came out. (+1.5 years)
Check your wring on the plug and check to see if the ULT is connected to the VSS wire.
Most likely this is where your CEL is coming from.
If it is cut the wires from the ULT and reconnect the jumper wires so the stock computer can see the VSS signal.
ChefJ shoot me a PM with your number and I will call you when I get to the shop (5:00pm CST) and I will walk you through the fix.
