Boost
Old Aug 29, 2007 | 11:42 AM
Headchef's Avatar
Active Streak: 30 Days
Default Boost
Is anyone out there running more than 10lbs. of boost with a supercharger without having done any internal modifications? If so, how many miles have you been running it and have you experienced any problems?
Old Aug 29, 2007 | 11:58 AM
CourageOO7's Avatar
John Z. and Sideways are both boosting over 14 psi...John Z. is pretty much on a stock motor with some head work (if I remember correctly)...
Old Aug 29, 2007 | 12:12 PM
Headchef's Avatar
Let me ask you this-what if any mods are needed to go above 10lbs.? I know how to get there-pulley but can the motor in stock form handle it?
Old Aug 29, 2007 | 12:49 PM
John_Z's Avatar
There are a few of us pushing 14psi or more on supercharged setups. All you need is a healthy motor, proper fuel management, and a solid tune.
I run a stock bottom end with a built head.
Old Aug 29, 2007 | 01:18 PM
Spec_Ops2087's Avatar
search headgasket...
Old Aug 29, 2007 | 01:33 PM
Silver S2k4's Avatar
lol, I ran 13psi on stock motor and it was great for about 50-60miles then I started having a little issue with the large amount of smoke coming out of the exhaust and I didn't drive much after that.
Headgasket and a map sensor, with 750cc injectors and EMS and you're set.
Old Aug 29, 2007 | 02:52 PM
CourageOO7's Avatar
You don't necessarily need a headgasket at these boost level. John Z. and some other Comptech guy are doing it all without an HG. I can't remember if Sideways is running an HG. There are plenty of guys running 12 psi without HG's without issues...
To make a long story short, you'll need an excellent engine management system and larger injectors and a good tune. Excellent EMS usually means running an AEM EMS on our cars though there are guys running the Greddy Emanage with success.
Old Aug 29, 2007 | 05:59 PM
It is strongly recommended to get a headgasket, and greatly lowers your risk of blowing up. You will get less hp and less headaches.
Old Aug 29, 2007 | 09:20 PM
He said over 10psi. I'm making a very general statement. Maybe he wants to run 18psi...no way your going to get away with that without a headgasket
Old Aug 29, 2007 | 10:13 PM
EriS2k's Avatar
12 psi Comptech SC Stock Engine, Runs Great!
