Boost Actuated Cutout & Cat Options
Old Apr 23, 2010 | 10:32 AM
dsddcd's Avatar
Default Boost Actuated Cutout & Cat Options
So I am planning on putting in a boost actuated cutout from Sound Performance as well as a catalytic converter on my new build. As you can imagine I am planning on having the cat post cutout but if I go too far I am afraid that the cat will never light off and just be a restrictions.
(1) What size is the factory exhaust, 60mm?
(2) Has anyone placed a 3" cutout in the test pipe and had plenty of room?
(3) If I put the cat just beyond the factory house flange will it get hot enough to light off?
(4) Should I get the 2.5" or 3" Cutout?
Old Apr 23, 2010 | 02:19 PM
deathsled's Avatar
Well you have an inline pro kit with a 3 inch downpipe don't you? Why would you want to put a 2.5inch bottleneck in there?
Old Apr 23, 2010 | 02:36 PM
camuman's Avatar
agreed. after seeing what joey just did, 3" FTW
Old Apr 23, 2010 | 03:24 PM
dsddcd's Avatar
Should have mentioned that I have a 2.5" DP now, but those details will come later.
Old Apr 23, 2010 | 04:41 PM
TRBOKEV's Avatar
You NEED the 2.75!
Phil had one....
Old Apr 23, 2010 | 04:42 PM
Revenge's Avatar
I added a 3" magnaflow cat to my set up and really lost no power. I actually made more power with a AEM, Intake and CAt over the Emanage no intake and no cat.
Old Apr 23, 2010 | 04:46 PM
dsddcd's Avatar
If I put in a cat it will be 3" and I will use reducers basck to 2.5"
Old Apr 23, 2010 | 08:37 PM
Sideways's Avatar
OK, why?
Old Apr 25, 2010 | 10:00 AM
dsddcd's Avatar
Originally Posted by Sideways,Apr 23 2010, 11:37 PM
OK, why?
Why #1 - To increase the cross sectional area to effectively lower the resistance.
Why #2 - The plan will be run a low boost (Wife) tune with the cutout closed and a high boost with the cutout open. This will allow her to run 10-12PSI on low boost and make good power still.
Why #3 - As Trbokev tells me I like to make things more complicated then they have to be.
Old Apr 25, 2010 | 12:12 PM
Sideways's Avatar
As I thought, I did the 5 inch Random Technologies cat necked down thinking the same thing. FYI, it didn't last 80 miles and totally plugged the exhaust system costing power and a big chunk of money. Now it is a funny looking test pipe.
