boost controller recommendations
Old Jul 29, 2019 | 09:16 AM
yamaha6611's Avatar
Default boost controller recommendations
my cheap ball and spring bleed style controller needs replaced.
i just want a normal manual controller... but im seeing a huge price difference online... turbosmart is either 100 or 35??
why?
and any other recommendations would be helpful. thanks,
Old Aug 2, 2019 | 07:30 AM
scottdh20's Avatar
ecu controlled is the best but with that said, i used a turbosmart dual stage boost controller in the past and as far as a non-ecu based boost controller goes it was amazing. used for 3-4 years with no hiccups. it has two knobs you dial in and wire up a toggle switch. allows you two boost settings you can toggle between. nice for a street/daily boost level and flip a switch to a "kill" tune.
Old Aug 3, 2019 | 08:42 AM
AP1Chief's Avatar
ECU with a MAC valve is best, but if you must stay manual, HALLMAN Pro hands down, was the best manual controller ive ever used.
Old Aug 4, 2019 | 03:36 PM
yamaha6611's Avatar
ok cool so... heres the more tricky part... all my vacuum lines to the wastegates use braided lines and -4AN fittings, which go down to the cold side charge pipe. is anyone familiar with a boost controller that can use AN fittings and not just barb fittings? i know a lot of them have removal barbs and i can purchase AN fittings...
Old Aug 9, 2019 | 10:58 AM
soulicious's Avatar
Why not just use a standalone like AEM V2 or Infinity? You can use AN fittings with the proper adapter using a MAC boost solenoid with that setup.
admans2k
Feb 20, 2014 06:49 AM
BrockB
Nov 22, 2010 09:30 PM
crav3s2k
Feb 17, 2009 05:48 PM
JoeyBalls
Mar 21, 2008 06:35 AM
2QYK4U
Jan 27, 2007 08:22 AM
