Boost controller recommendations
Old Nov 17, 2010 | 09:26 PM
  #21
NaturalAspirations's Avatar
The Blitz SBc i-D works fine for what you need and dosent take up as much room as the gauge style systems from Turbosmart and AEM do. No need to call attention to your self with gauges that just get in the way, these cars are cramped enough.
Old Nov 17, 2010 | 09:51 PM
  #22
BrockB's Avatar
Originally Posted by 04Briggs,Nov 17 2010, 09:17 PM
here's a link to evan's tuning with a good comparision of controllers
http://articles.evans-tuning.com/2009/03/2...ler-comparison/
Im really looking into the turbo smart eboost 2 too...
Old Nov 17, 2010 | 11:32 PM
  #23
EternalLx's Avatar
Originally Posted by JoeyBalls,Nov 17 2010, 06:48 PM
Not sure? I believe Evans has the failsafe setup to pull timing and dump fuel, but not lower the boost, I am going to send him an email and fine out
Both Maps run Meth
Let us know what he says Joey cause I wanted to run a high/low switch also but am in the same situation as siadam using the switch to trigger meth failsafe.
Old Nov 18, 2010 | 05:46 AM
  #24
InductionPerformance's Avatar
I've ran a lot of boost controllers over the years. I usually stick to using a boost control solenoid with the ems or an AMS boost controller. So I would highly recommend either the Blitz SBC-iD or AMS 500.
Old Nov 18, 2010 | 05:54 AM
  #25
dsddcd's Avatar
Originally Posted by 04Briggs,Nov 18 2010, 12:12 AM
i'm using the aem true boost. you can use three settings with it (one being off using the waste gate spring), you can also wire in a scramble boost and warning light. I've had no issues with it.
Yes, but was is your experience with other controlers?
Old Nov 18, 2010 | 06:18 AM
  #26
spectacle's Avatar
I would like to point out that this portion of that article:
[QUOTE]Gear Based Boost: Gear based boost feature is found on the Hondata s300 and Hondata Kpro systems.
Old Nov 18, 2010 | 07:38 AM
  #27
DBXFX's Avatar
Originally Posted by JoeyBalls,Nov 17 2010, 04:05 PM
I have a High/Low (on/off) switch for my setup, its done via EMS using the AEM Boost control solenoid
Teach me about this aem boost control. I got the 1052 coming in this week and getting retuned on wednesday with the aem solenoid. Will the tuner have to setup 2 completely different maps for high/low boost? Is there a switch port on the ems that I can connect a toggle switch to, to switch between boost levels? Is there a boost limiter function/ warning?
I was originially going to use the profec b spec II (which is currently for sale) but I switched to ems from emanage and decided to go with the solenoid.
Thanks
Old Nov 18, 2010 | 08:38 AM
  #28
JoeyBalls's Avatar
Thanks
Don't know much about it to be honest, contact Evans, he will know. I have the same tune, just one lower boost, one higher
Old Nov 18, 2010 | 08:43 PM
  #29
Originally Posted by spectacle,Nov 18 2010, 07:18 AM
I also want to second dsddcd's assertion about boost controller feedback...it would be really nice if the ECU could adjust the boost within a certain +/- (like o2 feedback) to achieve a certain pressure. When the weather changes, so does your max boost with the Hondata based systems.
MoTeC and AEM EMS can do this if setup correctly
Old Nov 19, 2010 | 07:33 AM
  #30
PUNCHIN-IT's Avatar
I had the Profec B Spec II, but I now have the AEM tru boost. The profec B spec II was easier to control and read. The AEM is nice because you can mount it on the pillar. It also goes nice with the AEM UEGO. I feel like the AEM truboost controls boost better than the Profec B Spec II though. Truboost is dirt cheap also.
