Boost + ems + etest....need some input
Old Aug 21, 2016 | 03:29 PM
Ap1s2kay's Avatar
Default Boost + ems + etest....need some input
Hey guys, so I finally finished up my build, happy and all can't wait to drive it, take a look at my plate and yah, plate tag expired and of course I need an etest to renew. I'm running aem ems series 2. I'm located in Ontario, Canada and our emissions tests consists of a obd2 plug in. From what I'm aware of we are close to the same emission requirements as you Cali guys. How are you guys getting around this?
Old Aug 21, 2016 | 03:37 PM
S_DosMil's Avatar
Paying for an illegal smog or taking everything off.
Old Aug 21, 2016 | 03:39 PM
LDfavoriteson's Avatar
If you're supercharged you have to put on the stock map sensor, remove the sc belt, put on the stock injectors, and put the stock ecu in...
Old Aug 21, 2016 | 03:53 PM
S_DosMil's Avatar
It still wouldn't pass the visual.
Old Aug 21, 2016 | 03:54 PM
Ap1s2kay's Avatar
Running a sheepey built kit on e85, if I put stock ecu in it will for sure set off a million plus codes as i delete all my air and emissions junk I don't know if any of you guys are from Canada but is there some way to be able to push for a sniffer test instead of getting plugged in
Old Aug 21, 2016 | 04:14 PM
S_DosMil's Avatar
Is there a visual test like in California? What year is it? Over here anything 2000 up I believe gets the obd test. Mine is a 2000 and I still get sniffer
Old Aug 21, 2016 | 04:16 PM
Ap1s2kay's Avatar
No visual, I have a "Payable" way of getting around it but because mine is 03 it needs to be plugged into obd2 port. The car doesn't even need to be running just ignition on.
Old Aug 21, 2016 | 09:45 PM
I forgot to add putting the stock cat on...my bad
Old Aug 22, 2016 | 01:01 AM
riceball777's Avatar
Don't know about your laws but most of the car guys here in California all just pay someone off and do illegal smogs.
Old Aug 22, 2016 | 03:41 AM
S_DosMil's Avatar
With supercharger bracket and supercharger mounted any regular shop will turn you away. It can't look like you have anything. If you know someone then yeah I'm sure you could get away with it.
