boost limits of 91 octane
Old Apr 23, 2014 | 06:17 AM
killerbee_vr6's Avatar
Default boost limits of 91 octane
how far are people taking superchargers on 91? I know that SoS says that 9psi is the safe limit. I ran 11psi on my old KW kit for about a year, but that's not long enough to see the end result. seeing 8.7 psi at 8500rpm now on a CT 1200 oil fed kit on 91.
Old Apr 23, 2014 | 07:24 AM
passmans2kny's Avatar
theres is no definite answer for this question, let ur tuner decide whats safe once the car is being tuned
Old Apr 23, 2014 | 07:48 AM
1SlowSi's Avatar
I will tell you from experience that you CAN make 500whp on 91 but you will have to have an efficient turbo setup with a low compression motor. For a supercharger and your specs, you will be fine with 91 octane. A lot of San Diego guys with superchargers are making 360-400whp, stock motor, 91 octane, 10-12 psi.
Old Apr 23, 2014 | 09:11 AM
riceball777's Avatar
I don't have a super charger but I make 442whp at 14 psi on the stock engine on 91 octane. I have seen many low compression built motors make over 500 whp at 20 or so psi on 91 octane.
Old Apr 23, 2014 | 09:19 AM
s2knoob89's Avatar
440whp at 13.5 psi for the last 20k miles on stock motor with my turbo setup. 12-14 psi should be safe aslong as your tuner knows what he's doing.
beechx1
Apr 4, 2017 02:54 PM
EK9MAX
Jun 28, 2010 03:59 PM
Iceman1
Nov 23, 2005 07:48 AM
S2KJimmy
Jul 30, 2005 03:23 PM
SuzukaS2K
Mar 4, 2003 06:58 AM
