To boost or not to boost?
Old Jun 4, 2013 | 06:14 PM
Satansedan's Avatar
Default To boost or not to boost?
I have an 01 BB S2k, with roughly 136k on her.
Im getting a Turbo kit this weekend, for a pretty good deal.
My question is:
My car uses oil ( about a quart every oil 3k miles)I do drive the car HARD.
I added some lucas and it stopped, but I can still smell oil burning sometimes.( car has NO leaks anywhere)
I run Mobil drive clean 5000 10w-40, and the car has the infamous "random smoke issue" when coming to a stop or taking off but not in high rpm's.
I was debating on taking my intake off and cleaning it out thoroughly and bypassing the pcv valve with a catch can to see if it helped.
I also debated on changing the valve stem seals and changing the springs and retainers while I was at it.
There are a few Turbo S2k's local to me and they run Brad Penn 20-50 race oil, I was worried about running something that thick due to the small oil galleys in our engines.
Compression test went as follows:
#1-220
#2-230
#3-225
#4-230
So would you boost the car now ( not daily driven) or wait and send a spare block to Laskey down the road and go boost then?
Hmmmmmmm.
Old Jun 4, 2013 | 06:23 PM
helloimsteve's Avatar
I'd boost it. My compression was around the same and I boosted at 132k. Granted my motor didn't last long after that (because of a shitty tune), make sure you get a really good tune.
The random smoke is a little concerning though. Usually random smoke when decelerating is something in the head. Maybe valve seals or something. Have a leak down done. If the numbers are good, eff it and boost it! Lol.
Old Jun 4, 2013 | 06:25 PM
Satansedan's Avatar
I learned my lesson about a good tuner... Colombia from CMB Tuning will most likely get my business.
If not him, Mase for sure!
Old Jun 5, 2013 | 08:58 AM
Satansedan's Avatar
Anyone else run 20-50 oil?
Old Jun 5, 2013 | 10:05 AM
camuman's Avatar
10w40 here. and if you dont boost it then its slow. so the real question is to be slow or not to be slow......
Old Jun 5, 2013 | 10:14 AM
Redline S2K's Avatar
10w30 castrol titanium and booooooost it.
Old Jun 5, 2013 | 11:04 AM
rikhemi's Avatar
Smoke at Decel can be a bad pcv valve. Had a smoke decel issue with my turbo setup.
Old Jun 5, 2013 | 01:41 PM
Satansedan's Avatar
Hmmmm.
Old Jun 5, 2013 | 01:49 PM
AutoXs2KXx's Avatar
Boost her!
Old Jun 5, 2013 | 04:01 PM
Satansedan's Avatar
Originally Posted by AutoXs2KXx
Boost her!
