boost problem
Old Apr 28, 2015 | 06:07 AM
Hershey's Avatar
Default boost problem
So here my problem I'm trying to get my boost sorted out. The wastegate is a tial 44mm mv-r with a 10 lbs spring. Aem series 2 Wire up with Mac boost solenoid. The car is semi street tune and is able to drive regularly. The problem comes in when I get on boost, the car just wants to run pass 15 psi. I got my boost cut at 12 psi right now and everything is zero out on my aem boost setting hoping the car will stay at 10psi. I just need to figure this out before the I go on the dyno may 4.
I'm currently on this set up
https://www.google.com/search?q=aem+...07%3B800%3B514
My set up
2000 ap1 f20c at 127,xxx miles
leak down and compression test is a healthy motor.
Upgraded ap2 retainer
upgraded oil jet bolts
stock everything
pfab eltm
Garrett gt3582r bb w/-4an .035 restrictor
1.06 ar single scroll t3
3in down pipe to e cutout
pfab intercooler piping with cx racing intercooler. Same specs as pfab stage 3 intercooler
Greddy bov
id1000
aem 320 e85 pump
Aem fail safe
aem water temp
aem oil pressure
aem series 2
competition stage 4 clutch
The car will be tune on e85.
Old Apr 28, 2015 | 12:02 PM
biohazarde's Avatar
Where are you reading the 15psi? From a stand alone gauge, or from the ECU itself?
Old Apr 28, 2015 | 12:33 PM
Hershey's Avatar
From my data log on the ecu and my aem failsafe log.
Old Apr 28, 2015 | 03:58 PM
KaNgArOo's Avatar
Very similar setup to mine. I dont know what a solution to your problem might be, but ive heard of the new tail mvr wastegate to not be as reliable as the old tail 44mm wastegate s.
Maybe a bad wastegate?
Old Apr 28, 2015 | 09:16 PM
Hershey's Avatar
I hope it's not a bad wastegate.
Old May 1, 2015 | 04:43 AM
Hershey's Avatar
Anyone
Old May 1, 2015 | 10:47 AM
S2K-F8's Avatar
I had the spring in my Tial wasgtegate snap in half and cause me to overboost (and blew my motor)....might be worth checking
Old May 1, 2015 | 11:45 AM
Hershey's Avatar
I just put this in brand new. I install the spring myself too. I'll double check.
Old May 1, 2015 | 11:54 AM
S2K-F8's Avatar
Gotcha....probably not the issue then. Vac lines hooked up properly?
Old May 1, 2015 | 11:57 AM
Hershey's Avatar
Is my bov soppose to be open at idle? I have a e cut out to the stock exhausT. With my cutout close my bov doesn't leak air out
With it open it leaks air out. Is this normaL? Greddy type s
