Boost Question for anyone wish answers!
Old Mar 5, 2006 | 07:34 PM
SpokaneS2000's Avatar
Thumbs up Boost Question for anyone wish answers!
Just started the S today. We got my comptech s-c with the aftercooler on and for some odd reason my boost gauge is only saying two pounds....anyone got and answers or ran into this before. what should i be pushing?
Old Mar 5, 2006 | 07:42 PM
04RioS2k's Avatar
I believe it should be around 5 pound for standard pulley.....
Old Mar 5, 2006 | 07:43 PM
PilotKD's Avatar
Does the car feel like it has 90whp more? You could have a loose intake hose somewhere or the belt slipping.
Old Mar 5, 2006 | 08:04 PM
we havent taken it out yet....it was still in the garage so...my guy just thought it was wierd that it was only reading two pounds....
sounds great though
Old Mar 5, 2006 | 08:11 PM
Slows2k's Avatar
At idle your boost gauge should read 20in Hg, or 20 in of vacuum. You will only see max boost at max RPM. 2nd & 3rd gear give you the longest time to take a look at the boost gauge, Redline in 1st should come up pretty quick, and only hit peak boost for a moment.
At approx 4000rpm you should have 1 psi.
Old Mar 5, 2006 | 08:19 PM
ok we werent sure because like i said we havent gotten a change to take it out yet...just got it done about ten minutes ago. we still gotta put on the hood and all that good stuff...i got the sparco shift indicator as well....
Old Mar 5, 2006 | 08:54 PM
xviper's Avatar
sounds great though
As Slow just indicated, a supercharger like the kind you have, gets to max boost at max rpm (redline). Why would you even think it would read max boost running in a garage? Even if you rev it to redline (not a smart thing to do) in the garage, unless you hold it at redline for several seconds, you won't see max boost on a gauge.
Old Mar 5, 2006 | 09:00 PM
well like i said thats why i was asking you guys so....this is my first supercharger so, im learning by talking to you arent i....it was simply to put on the fuel pump was a pain but other than that it wasnt too bad i just wanted to ask a few things....so the five pounds kicks in around redline in every gear?
Old Mar 5, 2006 | 09:08 PM
xviper's Avatar
Yes, but with a MY2000, you should be pushing closer to 6 psi at redline. Since 1st and 2nd will go be pretty fast, it won't be till you redline 3rd or higher that you will actually get a good read on the boost building up. Of course, this will also depend on how accurate and how easy it is to read the boost gauge you have.
Old Mar 5, 2006 | 09:10 PM
i have a carbon fiber series boost gauge...do you have any advise on what some of the first things i should do are....
