Bov
Old May 29, 2008 | 05:44 AM
  #21
REVHIR's Avatar
Anybody?
Old May 29, 2008 | 06:11 AM
  #22
ZSAK's Avatar
i would think any bov would work great, just depends on what brand you prefer. A lot of people like the greddy type rs and the hks ssqv. If I ever change my inline pro bov I may get the hks I suspect though that no matter which way you go you will have to weld in a flange to make it work. As for the type r bov I am not too sure what the specs are on it.
Old May 29, 2008 | 07:11 AM
  #23
REVHIR's Avatar
Well I went through with it and bought the GREDDY TYPE R bov w/stiff spring. I will inform on how it does. I have not been able to get any reviews.
Old May 29, 2008 | 07:52 AM
  #24
Spec_Ops2087's Avatar
Originally Posted by NFRs2000NYC,May 29 2008, 12:30 AM
That's odd. I had it working fine, then when I messed up the hose routing, Synapse fixed the problem very quickly. Looking at the photos on the inlinepro kit, the pipe going into the throttle body is where I have mine....looks like it's the same "technically" as the greddy kit. 2 nipples are connected to the vacuum block, and the side one is connected to an intercooler pipe. Works exactly as advertised. Maybe your's was defective?
I tried 2 and a number of different springs.
Its just the placement of the bov on the IP kit. Being that its on the compressor side some surge will result with this bov.
Old May 29, 2008 | 10:24 AM
  #25
H.A.R.T B18C1EG6's Avatar
a lot of high HP supras run the greddy type R. Im pretty sure it'll hold up fine for you
Old May 29, 2008 | 06:42 PM
  #26
Jc S2K2's Avatar
i had inlinepro BOV then now using Greddy type-RS. it fit without any modification to charge pipe. direct fit. also it sounds much better. also running on GT35R.
Damir314
Feb 4, 2013 04:05 PM
kerm1t
Dec 20, 2012 11:51 PM
lazymashi
Sep 2, 2011 05:58 AM
91crxdx
Mar 31, 2010 11:54 PM
JoeD
Jul 8, 2002 04:51 AM
