Which BOV are you running with Comptech SC Setup?
To those of you running the HKS or Greddy, I'm assuming that you needed a custom mount welded together to use on the Comptech? Post some pics, if you can...
I've personally never seen anything other than a Godzilla valve on the Comptech kits...
FF2Skip, I think it works better than the by-pass valve that comes stock on the kit. I think my by-pass valve was bleeding off boost at high RPM's My car felt much stronger after the BOV.
RAT
RAT
Originally Posted by yellowknockers,Jan 7 2005, 11:02 PM
I'm running the Godzilla, it's nice, more of a wooshing sound than your normal turbo BOV sound. Make sure to cork/seal the bypass valve on the intake/compressor inlet hose though.
Originally Posted by revhi,Jan 9 2005, 11:03 AM
yeloscreamer has the HKS. He posted pictures before. Use the search bar. Youll find tons of info on BOV's.
Originally Posted by revhi,Jan 10 2005, 11:30 AM
I can hear mine starting about 2000 rpms. It constantly leaks air, so I can hear it at idle or cruising also. It gets louder as you rev higher.
I agree with Skip. I have it for the noise.
