bradshit turbo setup (norway)
PFAB Equal Length V-Band Manifold/got kit that has the WG close to the valvecover
PFAB 3" V-Band Downpipe
PFAB V-Band Dumptube
GT 3076 tial V-ban 82 AR
PFAB intercooler piping
vibrant 875HP intercooler
Blitz sbi id 3 boostcontroller
44mm tial WG/ 0,5bar
50mm tial Q poppoff
ARP Manifold Studs
ACT street disc and heavy duty pp
AEM EMS
Walbro 255
Bosch Injector 1000cc, saturated
http://www.t1raceparts.com/product_p/id1000-s2k.htm
Mfactory oil relocator kit
vibrant vacum savanger
BUDDY CLUB HOSE SENSOR ADAPTOR / innsted of temp fix
beather tank
omni 3 bar mapsensor/RED : http://www.omnipowerusa.com/calibrations.doc
Exhaust /invidia singel with test pipe
cometic 2mm headgasket
thermotec exhast wrap
black turbo blanket
13 row blue oil cooler with earls plumping
STRI 60mm gauges RED /boost , water
STRI 52mm gauges GREEN/ oilpressure , oil temp
seibon carbon hood TS style
seibon carbon spoyler mg style
visracing carbon J`s front bumper
APR carbon cooling plate
APR carbon sparkpluge cover
carbon crossbar
Feels reardifusser
kw variant 3
front strutbrace
type on racing axel spacers
5zigen fn01r-c matblack 17ince
5zigen blue open ended lugnuts
falken RT615 225/45 and 245/45
how much more boost can the s2000 handel with 2mm gasket ...?
or best to just keep it stock sins...Cams will be a little off sins thicker headgasket and will not gain that much more power with 2mm gasket ?
sorry for my english but im form norway
50mm tial Q poppoff
ARP Manifold Studs
AEM EMS
Walbro 255
beather tank
black turbo blanket
carbon crossbar
Feels reardifusser
kw variant 3
front strutbrace
Originally Posted by Momentum,Apr 27 2009, 10:34 PM
Im running the stock headgasket and have boosted to 30psi, seems good to me.
I said it like that for a reason, it's no better or worse than saying "i run xx psi on a xx headgasket" without knowing everything about your setup (most importantly fuel which nobody has mentioned yet) Trying to say an F20c is good for xxPSI on xxCR is pointless, if you have good knock detection (knockbox or JS safegaurd) and a good tuner you can easily get away with 20-22psi on pump gas and obviously much higher on race gas. Of course that assumes your going to pay attention to your car and check logs on a fairly regular basis since you don't have much room for change.
A thick headgasket is a bad bandaid you sacrifice combustion chamber design most importantly your quench area which plays a huge roll in knock control and combustion efficiency.
To be perfectly honest I don't have many miles on the motor but pretty much every mile I have has been hard, been to the drag strip a few times on the dyno for days (literally) and on the street on occasion, I run an ethanol blend and will soon be going to the road course running ~28psi on a stock motor from valve cover to oil pan to see if it can take it. Can't really give a mileage estimate as I have no odometer.
thanks , jepp im thinking of just going stock and pulling like 8psi-9psi first ...
sins we got 98 and 99 octain on pumps here ill think ill be alot safer , for in US you only got 93 pump gas ???
and i will go down on the timing so thats not to hard !
psi dossent kill .......Detonation kills...!
Originally Posted by s2kswe,Apr 29 2009, 02:54 AM
Warning. The gas mentioned as 93 octane in the states is actually as good or sometimes even better than the gas we have here in sweden/norway. A tuner told me the US gas have some additions that prevents knocking etc. He had tried both. The numbers cant be directly compared.
The US octane ratings are an average of MON and RON figures: (MON + RON)/2 and are typically 5 lower than the European RON only number.
i.e. Euro 98 Octane is approx USA 93 Octane.
so there is nothing diffrent in the gas in usa then in europa ...
just the way they messure it
So there is notthing diffrent stuff in the gas you can tell youre tuner
Wow Momentum thanks for spewing lots of irreverent information into this thread. I think he asked how much boost was a 2mm head gasket good for, not how much boost you were running on your stock hg. If you feel like bragging about your car, go start your own thread where you can state cool facts like I boosted my stock motor to xx psi, im sooo cool, please be my friend.
Anyway, it seems like there has been lots of head gasket haters on this site lately. I think its because some people have been making lots of power with stock hg, which is fine for those who can get tuned at the best tuners, are rich enough to run race gas all the time or don
