Broken Vortech tensioner adjuster screw
Old Dec 7, 2009 | 10:27 AM
Moddiction's Avatar
Former Sponsor
Thumbs up Broken Vortech tensioner adjuster screw
Well I have a broken Vortech tensioner adjuster screw or bolt piece that is broken in half.
I cannot get it out. Bought a bolt extractor thing and it cannot grab it since it is like a screw and no head to grab it.
Pliers just slip and crush the threading and also will not grab.
Anyone know how to get it off? Got the new one in and ready to put in but need this out first obviously.
SC bracket and al are not in the car so can be carried around and all.
Old Dec 7, 2009 | 12:37 PM
drhess06259's Avatar
really small drill bit and bolt extractor.
Old Dec 7, 2009 | 12:57 PM
Moddiction's Avatar
Former Sponsor
Put a hole into the middle of it or something? I have a bolt extractor that goes over it but can't grip it as those are made more to grab a stripped head or something.
Old Dec 7, 2009 | 01:20 PM
JDR159's Avatar
Take it to a machine shop or find a friend with a drill press, and drill it mostly out. Start with a 1/16" drill bit, and work up from there until you've drilled about 1/2 of the ID of the bolt out. DON'T drill any larger than this or you'll risk getting into the threads in the bracket. Then use the extractor to pull it. By drilling out that much material, the bolt should come out easily.
Old Dec 7, 2009 | 01:48 PM
yes they make an extractor that kinda looks like a drill bit but backwards you drill out the middle of it like he said about half the size of the bolt. and then put the piece in there and back the whole thing out.....
Old Dec 7, 2009 | 02:06 PM
SgtB's Avatar
Picture?
Old Dec 7, 2009 | 03:05 PM
Moddiction's Avatar
Former Sponsor
This is what I am talking about. Hard to really get pressure on it as it spins and moves along the track in the bracket.
I just can't get the portion out that goes through the round shaped metal piece that connects to a pulley on the other side.
Old Dec 7, 2009 | 03:44 PM
you should be able to take the piece off the whole bracket if i remember correct. there is a bolt on the front side of it for the pully take that out. it has been a few years since i was vorteched but i think it comes off. might need to get the whole new tensior.
Old Dec 7, 2009 | 03:52 PM
Moddiction's Avatar
Former Sponsor
Yeah there is a bolt that should come off. Didn't have any way to hold it when I was trying so could not remove it. There is a bolt on the other side that attaches it to a pulley.
Old Dec 7, 2009 | 04:05 PM
Vette2K's Avatar
As I recall, that is reverse threaded, which means that a normal extractor won't work. Take the blower off the bracket so you can get some vice grips or channel locks on there and you shouldn't have a problem getting it off.
