Bulkhead fitting instead of tapping the oil pan?
I am installing a Vortech kit and was wondering what everyone's thoughts are on using a bulkhead fitting in place of tapping the oil pan. I measured the thickness of the oil pan to be about 0.22 inches after grinding down the cooling fins. This would only allow for 3-4 threads worth of engagement. With this small amount of thread engaement into aluminum it seems that one small impact from anything would destroy the threads, leading to leaks.
I would think that using something like this with two brass washers would be much better.
http://store.summitracing.com/partdetail.a...15&autoview=sku
My thoughts are 1.)One less step no tapping, 2.)Better seal, 3.) More robust since the nut and washer will spread the load over a larger area.
Originally Posted by Chris@SoS,Apr 30 2009, 01:36 PM
Consider welding if you are concerned about thread engagement. Bulkhead fittings are designed for smooth parallel surfaces.
regards,
-- Chris
regards,
-- Chris
Originally Posted by stack,Apr 30 2009, 11:53 AM
By welding do you mean to weld the fitting to the pan or add more metal to the pan so that there is more thread engagement?
Cheers,
-- Chris
I've been thinking about welding one of these oil baffles for the extra insurance.
located here: https://www.s2ki.com/forums/index.php?showt...&#entry15769798
I'm debating to trim an inch off where the AN fitting is welded... or if it will even make a difference...
