Calling all Meth heads !
Old Nov 12, 2009 | 08:02 PM
siadam's Avatar
Default Calling all Meth heads !
Man, that 1 gallon AEM container is bigger than I thought.
Where does everyone put theirs?
Thanks, and pictures will gain bonus points!!
Old Nov 13, 2009 | 04:07 AM
freshs2k's Avatar
I have my tank and pump behind the passanger seat bolted to that piece that holds the roll hoops. I had no where else to put it because my fuse box tucked and I have a sound system.
Old Nov 13, 2009 | 04:29 AM
S2Kart's Avatar
I use the washer fluid reservoir. Just tee into the line that is at the bottom of the reservoir. Since washer fluid can have methanol in it, the tank, tubing, and fittings are not at risk. I've had mine set up this way for about a year - no problems.
Old Nov 13, 2009 | 05:20 AM
camuman's Avatar
x2. the best way imho.
ditto, that bottle is enormous. it woulda been in my trunk if i hadnt had the sub taking up the well space.
Old Nov 13, 2009 | 06:07 AM
Envied's Avatar
So you still use your windshield washer with the meth?
Old Nov 13, 2009 | 06:09 AM
camuman's Avatar
cold weather washer fluid has meth in it. up to 30% i think. its not the end of the world. personally, i just run water in my bottle, but i never use the washer nozzles anyways. i just clean the windsheild now and then. but worst case you could use it if you had too.
Old Nov 13, 2009 | 06:17 AM
JoeyBalls's Avatar
if you want a 50/50 mix just use 3 bottles of heet and one bottle one windshield washer fluid. I am going to use a location that Chad has used, the bottle is in front of the radiator, behind the front bumper
Old Nov 13, 2009 | 07:30 AM
siadam's Avatar
My windshield resoiver is out of the question, I pulled it last winter when I did the wire tuck for the turbo junk.
I was looking in the same place as you posted Joey last night, I was wondering about that.
I could hide the pump in their somewhere, and it's not far to plumb either...
Although I'll have to trim the plastic or something, so I can still fill the container.
I think thats what I'm doing.
Where do you all mount the controller in the cab?
Old Nov 13, 2009 | 08:18 AM
JoeyBalls's Avatar
With my Greddy set up I had it underneath where the passengers feet were, but this time around I am going to put it closer, so I can test it while driving before I use it
Old Nov 13, 2009 | 08:28 AM
nextinstant39's Avatar
Depends how big the controller is. Be sneaky and put in your flip cupholder. I always wanted to hide the controller and have a hard top. Hook the
On/off switch up to the top button. Would be stealthy lol.
