Calling All You Alcoholics!
Old Apr 28, 2009 | 07:02 AM
Irishflame27's Avatar
Default Calling All You Alcoholics!
hey there,
i am in the process of getting parts together to boost my S, and i have always wanted to run e85, but was never really an option because we never had any local stations that sell it. Well lately a few stations around here now stock it and thats what i would like to run, i mean its pump race gas, why not right? i am planning on using a walbro intank pump, and bosch (injectordynamics) 1000cc injectors and shooting for 450-475ish whp on a gt3076 and equal length topmount manifold. with that being said, is a upgraded fuel pressure regulator needed, or will the oem ap1 reg. be ok. do i have to upgrade the fuel rail or fuel lines? any insight from the people that have done it would be great!
thanks for your time
Jeremy
Old Apr 28, 2009 | 07:46 AM
Peter@ISP's Avatar
Former Sponsor
im currently running regular braided lines without a prob. you can however upgrade them to the ethanol friendly lines if you prefer. i also suggest getting the fuel pressure regulator so you can run more base pressure and a gauge.
peter
Old Apr 28, 2009 | 08:00 AM
how do you feel about the aem regulators? i know the aeromotive is the best, but that requires and aftermarket rail and lines... do you have any pics of your setup?
Old Apr 28, 2009 | 08:28 AM
Peter@ISP's Avatar
Former Sponsor
im running modified aem fuel pressure regulator. i didnt bring my camera in today but i'll post it tomorrow.
peter
Old Apr 28, 2009 | 08:30 AM
s2kswe's Avatar
Sounds almost like my soon to be ready setup. ID1000s, rewired walbro and 3076 on a homemade tubular. Not topmount tho.
Old Apr 28, 2009 | 08:39 AM
peter
is it the remote mount regulator or the rail mounting one? are the regualtors the same as say the b series ones?
with ethanol being stoich at 9.7 and gasoline at 14.7, reading a wideband you would have to read in lambda correct? because rich and lean are different between the 2 fuels and reading in the normal afr readout only pertains to gasoline correct?
with AEM i want to have 2 tunes, one for 91oct and the other for e85
Old Apr 28, 2009 | 09:12 AM
Peter@ISP's Avatar
Former Sponsor
its the rail mounting one. i believe f series motor has different mounting position than the b series regulators.
you dont have to but usually you can set it up so it will read alcohol. (at least on dynojets)
that should not be a prob. make sure you completely out of e85 before running 91 oct.
Old Apr 28, 2009 | 09:22 AM
DO YOU HAVE A PART NUMBER FOR THE REGULATOR?
Old Apr 28, 2009 | 09:31 AM
Momentum's Avatar
you can leave it in AFR if thats what your used to and tune to 12:5 or whatever you normally would, the sensor reads lambda and calculates AFR based on the stoch ratio for your fuel so if you don't change the calibration your just looking at a multiple of the lambda number anyway.
most braided lines will work with ethanol although i had mr gasket braided lines that failed in a few days and replaced them with aeroquip which have lasted for a long time and show no signs of deterioration.
Peter@ISP's Avatar
Former Sponsor
aem part number 25-301
