Cant boost past 6 psi....
Old Aug 24, 2009 | 07:45 AM
jari8378's Avatar
Does your MBC/EBC require a breather? check the instructions... sometimes they require a breather which is a t with a small pin hole.
Old Aug 24, 2009 | 07:53 AM
blueap2's Avatar
It has three ports and one is left open. I know for a fact my vacuum lines are correct. I used to run the same boost controller on my previous setup and it worked fine.
Old Aug 24, 2009 | 09:59 AM
AndyFloyd's Avatar
swap the lines on the valve to the opposite of what they are now.
Old Aug 24, 2009 | 10:02 AM
blueap2's Avatar
Well fellas, I made this contraption:
http://www.vfaq.com/mods/ICtester.html
and I hate to say it but I found a boost leak at the intercooler coupler on the hot side. Im going out for spin right now to see what boost level I can achieve.
Old Aug 24, 2009 | 10:24 AM
jari8378's Avatar
^^ good ol' dsm resource...
Old Aug 24, 2009 | 11:22 AM
blueap2's Avatar
Dude what the hell I fixed my boost leaks, took off the boost controller, put it back on, reversed the vacuum lines off the controller and still the same problem...
Old Aug 24, 2009 | 11:51 AM
blueap2's Avatar
Just spoke to inline pro and they said I should be loosing a little boost since the dumptube is recirculated. However, my bet is that the greddy solenoid is messed up
Old Aug 25, 2009 | 04:06 PM
AndyFloyd's Avatar
can you just get a MAC solenoid to replace it? EBAY has em, same that AEM uses but a LOT less. Sorry i dont have a link....
Old Aug 25, 2009 | 04:09 PM
boostedf23's Avatar
I was always hitting 7psi on my old set up with a recirculated dumptube and 7psi wastegate spring. So i dont think that its the dumptube.
Old Aug 25, 2009 | 05:12 PM
blueap2's Avatar
I ended up integrating the greddy solenoid with kpro. Works great now, I also got her tuned but am making very, very low power
