car blew freeze plug out of head....
Old Aug 30, 2010 | 09:01 PM
  #21
CourageOO7's Avatar
Your car's grumpy and on the rag. Plug that with a tampon.
Old Aug 31, 2010 | 05:35 PM
  #22
ap1tuner's Avatar
Originally Posted by AusS2000,Aug 30 2010, 08:32 PM
You edited the first post? WHY?
I guess you don't realise that some people use the search function and consider S2ki to be a resource of users experiences. Now this thread contains a number of totally irrelevant responses.
Perhaps try starting a new thread for a new issue in future.
your right i didnt consider that when i edited the beginning. i sometimes feel like im over posting and clogging up the forums if i post too many threads (idk why, i just do). and i edited the post because i was worried that if i just continued my posting with my old posts, then the people and info i needed wouldnt see it at the end of the posts... my bad tho.
also, do you guys think the red locktite or jb weld would be best?
Old Aug 31, 2010 | 05:41 PM
  #23
Spoolin's Avatar
JB weld may be too thick and will just squeeze right out when you put the freeze plug in. They fit very tight anyway and thats why I mentioned using some red Loctite (which is watery, very strong and holds up to heat better) around the whole OD of the sealing area on the plug that seals to the head when you tap it in. I've seen it used on V8 rebuilds when they put the freeze plugs in.
Old Sep 1, 2010 | 02:54 AM
  #24
ap1tuner's Avatar
O ok. Makes sense. Ill go pick up a tube of it today. Thanks for the tip.
Old Sep 1, 2010 | 03:45 AM
  #25
Vi3tBoy's Avatar
They tried doing that with my car as well but it did not hold for me. So they ended up screwing in a plug
Old Sep 1, 2010 | 05:39 AM
  #26
ap1tuner's Avatar
^^ thats not reassuring..... dang. i hope it holds. if not then ill just have to buy a screw in. did yall just use a bolt that would fill the hole? or is there an actual freeze plug that you bought that screws in?
Old Sep 1, 2010 | 06:17 AM
  #27
teamvalorracing's Avatar
just measure the diameter of the hole. find a tap that requires that size. tap it. run a threaded block off plug in there, and have zero worries.
why replace it with the same kind of part that blew out???
Old Sep 1, 2010 | 06:52 AM
  #28
ap1tuner's Avatar
its pretty small so it shouldnt be hard to get a tap for the size. and ill probably go ahead and do that. but im still curious, why do so many of us have this issue? what causes this? until now, i never knew it could happen and now im hearing alot of people that this has happened to
Old Sep 1, 2010 | 10:06 AM
  #29
i havnt heard of it happening to "a lot" of people. especially not s2k owners. it must have something to do with air pockets. because superheated expanding air will blow freeze plugs like that. how long after the headwork was done did this happen? and did you get the air bleeding procedure done exactly right?
Old Sep 1, 2010 | 05:50 PM
  #30
ap1tuner's Avatar
this happened a year and 10k miles after the car was rebuilt and i was pretty sure it got all the air bubbles out.... but you never know.
