Cars at inline pro right now 1 question?
Old Dec 13, 2007 | 03:38 PM
DrewKC's Avatar
Default Cars at inline pro right now 1 question?
What size tire should I go with in the rear? I made a mistake before and their's 225/50/R16 on there now and they already look too small something to do with the stock tire is wider and when I replaced them they are just not wide enough. So any way what size should I run in the rear with a little over 300 to the wheels.
Old Dec 13, 2007 | 03:52 PM
CourageOO7's Avatar
max width you can run on the stock rims will be 255's...run those.
Old Dec 13, 2007 | 04:03 PM
TRBOKEV's Avatar
If you drive with 225 out back you'll wreck your car for sure! That is super unsafe.
Old Dec 13, 2007 | 04:13 PM
DrewKC's Avatar
thanks
Old Dec 13, 2007 | 04:24 PM
DrewKC's Avatar
one more question so would the tires be 255/45/17 or 255/50/16 which would fit or is better. sorry for the question..
Old Dec 13, 2007 | 04:55 PM
00wreckedS's Avatar
dude u have 2 different size tire (16/17") so... i'm gonna say the 16's since u posted u have them
Old Dec 13, 2007 | 04:59 PM
DrewKC's Avatar
Im an idiot
Old Dec 13, 2007 | 05:30 PM
lkingcuongl's Avatar
I am using 225's in the back. I will agree that it isn't the best idea. The tires are on the wheels to be used as winter shoes, so I don't drive it that often. We will see how I do once I get it back with the CTSC on it.
Old Dec 13, 2007 | 09:23 PM
TheCarGuy2021's Avatar
I've read on here that the 245/45/16 is the biggest for an AP1 rim (which is what I use). If I could, I would like to go with a 255 width. Are any of you running this size on the AP1 rim? If so, and problems? What size sidewall, 45, 40?
Old Dec 13, 2007 | 09:33 PM
Spec_Ops2087's Avatar
I recall hearing someone say they were running 275 (or maybe 285) size R-compounds on stock 16" rims so I would asssume 255 is fine.
