CDV, to keep it or not?
Old May 3, 2012 | 04:19 PM
JoeyBalls's Avatar
Default CDV, to keep it or not?
So, I dont dump the clutch, or powershift, so not sure if it will matter, but I do notice when I drag race, it just feels sloppy and not as crisp as I would like. Will removing the CDV put anymore stress on the tranny?
I have a CC Stage 4 clutch and 11lb CC flywheel
Old May 3, 2012 | 04:21 PM
spectacle's Avatar
Old May 3, 2012 | 04:24 PM
JoeyBalls's Avatar
haaha, I pre-load the Diff, and shift rather grandma like , hence my 11.7 @ 132 with a 1.9 60ft, lol
Old May 3, 2012 | 04:33 PM
Topillogic's Avatar
I asked Tony@T1 about this a while back. He said keep it and added that they retrofitted one to the race car. I'm guessing to make the shifts smoother and more consistent.
People that say it's cool to remove it so you can chirp the 2-3 shift confuse me. Accelerating hard out out of a corner would you rather break traction or slip the clutch a little?
Old May 3, 2012 | 04:34 PM
JoeyBalls's Avatar
^ Very good point!
Old May 3, 2012 | 08:41 PM
teamvalorracing's Avatar
I took mine out of my ap2. Id much rather burn a tire than a clutch. Much muchmuch easier to replace. Feels crisp and engagement is much more predictable.
Old May 3, 2012 | 10:38 PM
s2000Junky's Avatar
I totally agree.
But I have to say in Joeys special case for what he is doing, it might very well prolong the life of his trans with the power he is at. If he isn't burning up the clutch becuase of his slower predictable shifts, the CDV will offer a bit of cush.
Old May 4, 2012 | 07:27 PM
Spoolin's Avatar
I'm lost.......What's the CDV and what exactly does it do? Where is it located?
Old May 4, 2012 | 07:34 PM
japhethwar's Avatar
cdv-clutch delay valve. Located in the clutch slave cylinder on ap2's. Restricts the flow of fluid out of the slave, designed to cushion the engagement of the clutch to counteract the increased weight of the ap2 flywheel. Most people remove it to make the shifting quicker. Has been known to cause early clutch failure especially with stock clutches. I never had a problem with it using puck style clutches, but i removed mine when I went to a dual friction clutch. No complaints with it gone.
Old May 4, 2012 | 07:35 PM
jaundice's Avatar
CDV = Clutch delay valve. Only found on AP2's. It smooths out the flow of the hydraulic clutch fluid on engagement/ disengagement. Most people hate it because you can't feather the clutch or "drop" it like you can without it.
